BlackGMC build take 2 - Turbo Time
Old 09-26-2014, 12:51 PM
  #871
Resident Retard
BlackGMC's Avatar
I finally got around to replacing the meth pump. I used up my last bit of meth filling the tank back up. I am still undecided on whether to switch to 100% meth or stick with 80/20.
BlackGMC is offline
Old 09-26-2014, 01:04 PM
  #872
I have a gauge for that
Atomic's Avatar
What do you have against 100%?
Atomic is offline
Old 09-26-2014, 01:06 PM
  #873
oakley6575's Avatar
What pump did you replace it with?
100% meth will make the most power but 80/20 will take more heat out of that intake. Pretty sure I'm going to run 100%
oakley6575 is offline
Old 09-26-2014, 01:13 PM
  #874
Resident Retard
BlackGMC's Avatar
Nothing. I might as well give it a shot right? Is there any downside to running 100%?
Another alkycontrol pump.
BlackGMC is offline
Old 09-26-2014, 01:35 PM
  #875
Atomic's Avatar
May as well, makes it easier to just add it from the bucket and move on instead of measuring out water. Methanol will naturally absorb water from the atmosphere anyway.
Atomic is offline
Old 09-26-2014, 01:43 PM
  #876
Resident Retard
BlackGMC's Avatar
Good point. I always hated having togo. Get a gallon of water and 4 gallonnss of meth. Now i can just fill up my 5 gallon jug.
BlackGMC is offline
Old 09-27-2014, 07:20 AM
  #877
Laid Back
Beatdown Z's Avatar
Crank it up!
You probably already posted, but how you like the 3.90's?
Beatdown Z is offline
Old 09-27-2014, 10:22 AM
  #878
Resident Retard
BlackGMC's Avatar
I like the 3.90s. 2nd gear is slightly longer than the 4.10s i had previously. That was the main reaso. I choose 3.90s.
BlackGMC is offline
Old 09-27-2014, 04:59 PM
  #879
Resident Retard
BlackGMC's Avatar
12psi and a good dose of meth feels pretty righteous. I may leave it here or go up to 14psi.
BlackGMC is offline
Old 09-27-2014, 05:04 PM
  #880
oakley6575's Avatar
Jesus, you're an animal
Quick Reply: BlackGMC build take 2 - Turbo Time
