BlackGMC build take 2 - Turbo Time
Old 09-27-2014, 05:18 PM
  #881
Resident Retard
BlackGMC's Avatar
Jesus, you're an animal
I know it is not much compared to most but it is enough for me.
BlackGMC is offline
Old 09-27-2014, 05:21 PM
  #882
oakley6575's Avatar
I'm still at 12-13 right now on pump gas. It's perfect for daily driving
oakley6575 is offline
Old 09-27-2014, 05:24 PM
  #883
Resident Retard
BlackGMC's Avatar
You need some meth! I have 2 extra devils own kits
I am still at 16* of timing with meth i guess that is ok, i dunno if i should up the timing or not.
BlackGMC is offline
Old 09-27-2014, 05:37 PM
  #884
oakley6575's Avatar
Originally Posted by BlackGMC
You need some meth! I have 2 extra devils own kits I am still at 16* of timing with meth i guess that is ok, i dunno if i should up the timing or not.
I'll buy one off of you if you have the pump for AN fittings. I need a kit ASAP
Old 09-27-2014, 05:44 PM
  #885
Resident Retard
BlackGMC's Avatar
Yep i have one with and one without. I will PM you later with pics and prices.
BlackGMC is offline
Old 10-04-2014, 02:23 PM
  #886
Resident Retard
BlackGMC's Avatar
First step in redoing my fuel line. I moved the FPR over to the drivers side fender area.
Also i wrapped the lines in that shiny heat wrap stuff then put on some high temp heat shrink on the lines. I like it better that the shiny braided steel. I will be finishing up next weekend.
I gotta order a fitting to replace that blue one
BlackGMC is offline
Old 10-04-2014, 03:03 PM
  #887
oakley6575's Avatar
How is the FPR mounted there?
Old 10-04-2014, 03:09 PM
  #888
Resident Retard
BlackGMC's Avatar
I made a bracket that bolts to the frame. Tucked away down there the FPR is pretty much out of the heat path. Mounting it under the intake the fpr temps were 150*.
BlackGMC is offline
Old 10-04-2014, 07:49 PM
  #889
oakley6575's Avatar
Oh I see. When I first bought my intake I planned on putting it exactly where you did. Glad you got around to doing it before me. I'll make sure to keep it away from that heat.
Old 10-12-2014, 02:27 PM
  #890
Resident Retard
BlackGMC's Avatar
Fuel system V4.0. Hopefulky this is the last time.
BlackGMC is offline
Quick Reply: BlackGMC build take 2 - Turbo Time
