Blown 408(literally)
#124
That damn bolt is really bending me over. I couldnt get it off this morning so I pulled the engine with it attached and may have damaged the trans pump....luckily I still have my old trans I can put in for now.
On better news, I got the 408 in, but nothing is bolted up because of the torque converter screwing up and binding when fully seated in the trans. I worked on it today from 6:30 to about 8 tonight. I dont know how the hell you guys do engine swaps in a day without a pit crew. Im on day 3 tomorrow.
heres the 5.3 coming out,
I ended up just barely clearing the rad support when my tires off and sitting on the lca's.
#127
My performabuilt level 3 is non-functional thanks to a broken pump from pulling the converter with the flexplate...
So I got an extra fun time of swapping in the stock trans in along with the new engine, that was a nice 5 hour detour. The good news is the 408 is in, trans bolted up, and headers and ac are on. Although, I could not get the passenger side header in with the exhaust studs, so I am having to use bolts on that side.
After 3 days of this im exhausted and just want to be finished and drive again. Although the whole thing is bittersweet at this point because of my broken trans, and I really doubt the stocker would like the power plus the weight of my truck....
Should be driving tomorrow barring something else breaks. Damn Murphy.
#130
Tin Foil Hat Wearin' Fool
You broke the pump ring, since it wasnt running when you broke it the cage should be fine and not dinged up. 13 vane pumps are very common, sounds like Frank is trying to screw you. No point in having a "hardened" pump, it only moves fluid. You can find 13 vane pumps all over the place. When I built my old 60e a few years back I think I ordered mine off 4l60e.com. Might check with FLT, theyve always done me right on prices and helpful info. There arent any write-ups that I know of online but there are a few guys on here that build transmissions. Built 408 can probably help you with instruction on installing the part.
