Blown 408(literally)
#142
Well that should give you plenty of time to dial in the tune. Mind telling me what you have in the motor(pm if you wish)? I am wanting to build a 408 this winter with tax money. Thinking it will be around 4-5 grand so I need to start planning now. Curious on the cost you ran into and any problems you had to over come.
Im just glad I finally finished putting this thing in. Physically and mentally its been exhausting doing this by myself with no prior experience, and took about twice as long as I planned. At one point the only part of the drivetrain I had installed was the rear-end
Although it starting on the first crank really put a smile on my face
Anyone have any good write ups on how to replace the pump ring in the 60e?
#143
Oh and a final parts list:
2005 LQ9 block
K1 forged stroker crank
Diamond flattop forged pistons with valve reliefs
Callies compstar 6.125" rods
Custom cam by PatG
Stock 317 heads
REV 2.02/1.57" valves
Patriot Gold dual valve springs
comp hardened pushrods
LS7 lifters
rollermaster dual chain timing set
stock rockers
LS6 oil pump
stock 6.0 oil pan, windage tray, oil pickup tube, all covers, and crank pulley
All ARP hardware
All new GM gaskets
LS9 headgaskets
magnacharger crank pinning kit
Reused from 5.3:
waterpump
alternator
ac compressor and bracket
motor mounts
dipstick and dipstick tube
power steering pump
flexplate
Static CR comes out to around 11.1. Boost is provided by a magnacharger tvs1900 with 3" pulley, should be around 5-6lbs.
2005 LQ9 block
Custom cam by PatG
Stock 317 heads
LS7 lifters
stock rockers
LS6 oil pump
All ARP hardware
All new GM gaskets
LS9 headgaskets
Reused from 5.3:
waterpump
alternator
motor mounts
power steering pump
flexplate
#144
Ive been working on tuning the last couple days and have the fuel dead nuts on, and timing is at a conservative 15 degrees.....thing is though, it doesnt feel much stronger than my 5.3 did.... injector duty cycle is nearly the same as well, which tells me same amount of fuel = same power. The blower makes around 5.5lbs at full throttle whereas it was 11.5 with my 5.3
0-100 time is around 12 seconds
I attached the tune and log if anyone wants to take a look
