Blown 408(literally)
#51
I live in ohio so most of my stuff comes from Talmage,OH. I have oredered at 10-11 p.m. and get it at 12.pm or before the next day. I love it! Summit is AWESOME! Great customer service too!
#52
Heres a thread on 370 vs 408 if you have a few minutes.
https://ls1tech.com/forums/forced-in...your-help.html
Your going to be giving that 1900 a workout but with the compression and cubes this thing should have tonnnssss of low end!!
#53
Reading that thread makes me glad I bought the shortblock from a good shop in texas. I called them before I bought it and they have a pretty big presence in the racing world, so they must be doing something right.
With the cam pat spec'd out for me it should drive damn near stock, just with a lot more *****
#54
So a few questions about swapping engines...
-Do I need to remove the hood or radsupport/condensnor? I dont really want to if I dont have to, especially the condensor.
-Do you guys unbolt the trans, remove the driveshaft, and slid the trans back enough to clear the engine, or pull it all out at once, or what?
-Any tips? This is my first engine swap.
#55
i've never done it on a newer vehicle, but back in the day, we would unbolt the driveshaft and take everything out through the engine bay. you can use the heads/chain method, but an engine lift plate works better.
#57
i have one at the house for gen 1 SBC's but it won't work on our engines. IIRC it's for a carbed intake.
If you've got an engine lift (I have one and we might be able to work something out), a chain, and a few bolts, you can lift the engine out that way, but it's better to use the plate.
#59
got ya.
thirty second lesson on pulling out an engine... IIRC, first you wanna disconnect and label the harness connections. disconnect all of the coolant lines, depressurize the fuel system, and don't disconnect the a/c compressor if you don't have to; take off the fan assy, disassemble the fan shroud. that should be it as far as things under the hood goes. i'd remove the hood just to be safe. you might also want to remove your grille. unbolt the trans x-member and support the tranny, a floor jack should work just fine if you don't have a tranny jack. unbolt the d-shaft. once you've got the lift chain in place and the hoist in a safe spot, jack it up until the chain is taught and give it a little bit more to take the pressure off of the engine mounts. unbolt the mounts, then slowly pull it out to make sure you don't hit anything, then tear down if you need any help let me know. i'll be happy to lend a hand.
