Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#1352
We didn't realize what was going on till after we made the last run and looked at this vid I'm about to post, but basically it went out and ran 9.3's at 144 on 24 psi. As you can imagine we were scratching our heads. The new converter is crazy tight and we were blaming that. However, that is probably due to the fact that it was way down on power due to the heads not sealing. I can't stop watching this vid.....it's that wild.
#1353
Finally this thing is done uploading. What you are looking at is basically an upside down view from the bottom to the top, with the light focus on the radiator cap.
https://www.dropbox.com/s/ct9jjpsqwh5t1h0/GOPR0038.MP4
#1357
Damn what heads are you running.. iff you don't mind askin hope is an easy fix nothing major i had tha't issue last year in sealy bayou drag lifted both of the heads due to they where hand ported the thickness of the walls where thin they cracked at 22psi...
