Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 04-16-2014 | 12:19 AM
  #1381
JJ_TURBO's Avatar
11 Second Truck Club
I hope nothings its hurt, I ones read a case where they were lifting the heads and they kept running the car for some time, they knew the heads were lifting cause the cooling system was loosing water, don't know for how long they ran the car like that but nothing was breaking between runs... it was a boosted setup too.
Old 04-16-2014 | 07:03 AM
  #1382
silver-mod-o's Avatar
Hunt&Fisherator
4 ft breaker bar on those head studs should do the trick
Tighten them til JUST BEFORE they break and that's as tight as you can go...
Old 04-16-2014 | 11:09 AM
  #1383
sprayedenali's Avatar
what head gaskets are you running? just curious...
Old 04-16-2014 | 11:35 PM
  #1384
Blown06's Avatar
8 Second Truck Club
It's got cometics on it.
Old 04-17-2014 | 09:15 AM
  #1385
id will be interesting to see what they look like by now!
Old 04-18-2014 | 09:25 AM
  #1386
LA Verde 06's Avatar
any water in oil? had same problem on my 418ci build I started loosing water half a gallon almost ...ended up I lifted a head and had both compression in coolant system and water in oil..nothing broke I caught it in time just re surfaced head to ensure there straight and new gaskets and changed oil engine is still going hard
Old 04-18-2014 | 11:55 PM
  #1387
Blown06's Avatar
8 Second Truck Club
I haven't had a chance to drain the oil yet.
I had surgery on Wednesday and it has got me fuked up at the moment.
Old 04-19-2014 | 11:55 PM
  #1388
Blown06's Avatar
8 Second Truck Club
Originally Posted by Atomic
I dont think you are lifting the head, because if you were it is several hundred psi and like I said the engine would be broken by now. Do you have an A2W intercooler? Maybe your intercooler has an internal leak and is pressurizing the hex.
Sorry, I'm not following..........what does the intercooler have to do with the radiator?
Old 04-20-2014 | 08:11 AM
  #1389
Atomic's Avatar
I have a gauge for that
Are you sure its the engine cooling system leaking and not the intercooler system leaking?
Old 04-20-2014 | 11:36 AM
  #1390
His inter cooler is completely inside the cab.
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
