Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#1573
I have a gauge for that
Yea, the engine could use some improvement. If money was no object, mother ******* would scatter............lol
I've got somewhat of a plan:
Dart Ls next 430+"
All Pro 12-5's with their intake
Gear drive f3
on methanol
I could probably double my current horsepower with that set up.
Dart Ls next 430+"
Gear drive f3
on methanol
#1575
couple builds going on with darts latley on newer modle truck, lets see how they performe, i think they will be badass, that setup your describing is similar to what flacos 08 will run that madman is working on right now, should make some nasty hp
Dart Ls next 430+"
Gear drive f3
on methanol
Dart Ls next 430+"
Gear drive f3
on methanol
#1577
Much better design below the heads. 4-bolt splayed caps (strong than the 6-bolt cap on the ls), much better windage control (you can run a pan that doesn't hug the crank. It's cheap for what you get.
#1578
Yea, that truck should make mine look slow. I'm sure he will hold the procharger record for a while.
#1580
No, I just dropped it off last week. Plus I've got the injectors sent off, the converter is going back, I'm redoing the wiring, redoing the cooling system and doing some front end work. It might be a couple of months before it is back together. But it's gonna be bad to the bone when I get it back out. Too hot to run right now anyway.
