Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 12-26-2014 | 09:27 PM
  #1701
jmgak47's Avatar
Want to say it was only 10 lbs or so saved. That piece weight a lot less then it looks, was disappointed.
Old 12-28-2014 | 01:14 AM
  #1702
Blown06's Avatar
8 Second Truck Club
Your frame looks slick all painted up like that.
Old 12-31-2014 | 01:08 AM
  #1703
Blown06's Avatar
8 Second Truck Club
Got all the cutting done for the front coil over conversion, cut the front crossmember out, and cut those annoying things off the bolt in crossmember that goes under the motor. I must say, I'm sick of cutting and grinding on this thing. What a pain in the ***. Those original spring bucket where no joke. I didn't weigh everything, but figure about 50lbs. Once I get the rear lower a arm brackets braced back up, get the upper shock mounts on, and weld in the new crossmember.......I'm gonna do a little more cutting on the very front of the frame. That should be the end of the chassis mods for now. Here are some pics.
Old 12-31-2014 | 07:15 AM
  #1704
sprayedenali's Avatar
What are you gona do for shock mounts?
Old 01-01-2015 | 12:07 AM
  #1705
Blown06's Avatar
8 Second Truck Club
Make my own.
Old 01-01-2015 | 12:43 AM
  #1706
oakley6575's Avatar
You use a plasma cutter or what?
Old 01-02-2015 | 12:56 AM
  #1707
Blown06's Avatar
8 Second Truck Club
Just an angle grinder and a sawzall. I'm low tech over here.
Old 01-02-2015 | 09:39 AM
  #1708
ShredSled's Avatar
Gonna do just the 2 plates off the frame like DBRods?
Old 01-02-2015 | 05:25 PM
  #1709
MIGHTY6's Avatar
If I would have caught this thread earlier. I would have told you to bring it to Victoria and I would stub the front end ( right in front of the k member)with chrome molly. Kind of like they do to X275 cars. I've wanted to build me a late model truck. It seems there's no real direction were is going.....Big or little tires, twins or single turbo, tube or stock suspension.
Old 01-03-2015 | 12:47 AM
  #1710
Blown06's Avatar
8 Second Truck Club
I haven't seen his. Got any pics?
Yeah pretty much just a run what you brung and hope you brung enough kind of deal.
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
