Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#2044
Twin ID2000's per hole. At 90 psi they flow near 300 lb/hr each so I'll have the capacity for around 600 lb/hr per hole, give or take. Won't really need near that with this janky motor, but it will give room to grow. You can do a lot with 4800 lb/hr of methanol.
Honestly, I could probably get by with the single ID2000's at 90 psi as I'm guessing it'll need somewhere between 2000 and 2200 lbs of fuel at full power. But I'm giving myself some room to play and also, I'll likely be running this thing at the normal 43 psi of pressure for now.
Pump is an Enderle 990. I think it's good for around 15 gallons/minute.
Morris said the blower mod should help tremendously, so with the total changes I've got some good expectations. Not high expectations though for obvious reasons.
#2045
I've run into several issues with parts lately and it is keeping me from making any decent progress. I've been working on a trick as **** balancer that is almost done, you guys will like the pics of that.......then this intake needs to go back for "an adjustment". Once I have those two things behind me, I'll be back to where I was near a month ago and can make some decent progress.
