Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 08-25-2010 | 05:59 PM
  #241
blown02408's Avatar
02 w/ lowest mileage 2800
Originally Posted by Blown06
Damn, I was just reading your sig..............I want more details. Sounds like a serious setup. How much power/boost does it make, any track times?
It made just under 700rwhp and 15psi @6000rpm before I ran into serious belt slip. I made a new bracket and moved the procharger out onto it's own dedicated drive and it seems to be working, no more belt slip and a few more pounds of boost. I haven't been back to the dyno yet, but hopefully soon after I finish up a few things Track times will follow
Old 08-27-2010 | 02:10 AM
  #242
Blown06's Avatar
8 Second Truck Club
Thats cool, you should be well over 700 now. Funny, my last dyno session I was only able to pull to 6000 and made 700 too. That was with the 346, but the little d1sc was already making 20 psi at that point. Burned the tranny up on the dyno.
RidinChevySolo97 (05-26-2019)
Old 09-01-2010 | 08:31 PM
  #243
1989k1500's Avatar
Been working on it at all?
Old 09-02-2010 | 01:06 AM
  #244
Blown06's Avatar
8 Second Truck Club
try'n
should have more updates this weekend.
Old 09-05-2010 | 10:55 PM
  #245
Xtreme402's Avatar
I may have missed it but what is the diameter of tubing for the cage and the crossmember for the trans? Thanks, Preston.
Old 09-07-2010 | 02:21 AM
  #246
Blown06's Avatar
8 Second Truck Club
Not sure on the tubing size bro. I'm thinking 1-5/8" for the cage tubing. Not sure on the x-member. Maybe the mad-crew will respond.
I'm beginning to get a little frustrated with how slow this project is going. I still don't have the interior completely finished up. I have all these ideas for ways to improve on the truck from how it was, and each little project takes about 4x as long as I anticipated. For example, I converted the boost gauge over from nylon tubing to braided -an line, well there isn't enough room for the braided line in the pillar pod so that had to be modified. I also had to modify the factory pillar for fitment and bolted the gauge pod to it to prevent it from moving around. That autometer pod is really a pos. Why can't they make a factory replacements like for the dodge diesels???
I made a switch panel using the old a/c control box and a piece of aluminum that madman cut up for me. It turned out awesome, but took forever to make (paint and jb weld curing time). It will look like it came that way stock though so thats cool.
One thing that really pisses me off. For those of you who have removed the factory pillars..............do you break the damn clip off??? I'll be going to the dealer this week to buy the 3rd one. I've since drilled the hole in the cab a little bigger to prevent this from happening again.
Just venting, I had a goal to have the interior completely finished by last weekend. I've got pics of these little things I'm doing, I'll post them later.
Old 09-07-2010 | 05:48 AM
  #247
MADMAN's Avatar
Head Fabricator
The cage and crossmember is 1 5/8 chromoly
Old 09-08-2010 | 10:31 PM
  #248
1989k1500's Avatar
I had mine off a few times and never broke it. *shrug*
Lets see the pictures. I really wanna see this thing all done and on the ground, it looked so good before.
Old 09-13-2010 | 02:53 AM
  #249
Dewey's Avatar
i've never had a problem either. i took them off when my alarm was installed and when i was figuring out where to put my tweeters.
Old 09-13-2010 | 03:27 AM
  #250
Spoolin's Avatar
GFYS and STFU
I've broken a few but not enough to where I couldn't jam them back in. They are rather fragile though, not meant for assemble and disassembly too many times.
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
