Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#241
It made just under 700rwhp and 15psi @6000rpm before I ran into serious belt slip. I made a new bracket and moved the procharger out onto it's own dedicated drive and it seems to be working, no more belt slip and a few more pounds of boost. I haven't been back to the dyno yet, but hopefully soon after I finish up a few things Track times will follow
#242
RidinChevySolo97 (05-26-2019)
#246
Not sure on the tubing size bro. I'm thinking 1-5/8" for the cage tubing. Not sure on the x-member. Maybe the mad-crew will respond.
I'm beginning to get a little frustrated with how slow this project is going. I still don't have the interior completely finished up. I have all these ideas for ways to improve on the truck from how it was, and each little project takes about 4x as long as I anticipated. For example, I converted the boost gauge over from nylon tubing to braided -an line, well there isn't enough room for the braided line in the pillar pod so that had to be modified. I also had to modify the factory pillar for fitment and bolted the gauge pod to it to prevent it from moving around. That autometer pod is really a pos. Why can't they make a factory replacements like for the dodge diesels???
I made a switch panel using the old a/c control box and a piece of aluminum that madman cut up for me. It turned out awesome, but took forever to make (paint and jb weld curing time). It will look like it came that way stock though so thats cool.
One thing that really pisses me off. For those of you who have removed the factory pillars..............do you break the damn clip off??? I'll be going to the dealer this week to buy the 3rd one. I've since drilled the hole in the cab a little bigger to prevent this from happening again.
Just venting, I had a goal to have the interior completely finished by last weekend. I've got pics of these little things I'm doing, I'll post them later.
#247
#248
Lets see the pictures. I really wanna see this thing all done and on the ground, it looked so good before.
#249
