Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 11-28-2010 | 09:18 AM
  #301
zeake's Avatar
Originally Posted by custm2500
I know he was trying to keep cost down for now but no mater how stiff the housing is the axles will still break so the housing isn't the only weak point.
Yeah. Obviously it isn't the only weak part. LOL
Old 11-28-2010 | 11:51 AM
  #302
jasond26's Avatar
I don't think I have seen anyone break axles except heavy suvs. I think you will be just fine, looks killer.
Old 11-28-2010 | 12:08 PM
  #303
custm2500's Avatar
Ph.D. in HUBRIS
I am curious does anyone know what axles flaco is running.
Old 11-28-2010 | 03:04 PM
  #304
little03chevy's Avatar
love the truck!!! keep up the good work.
Old 11-28-2010 | 09:55 PM
  #305
1989k1500's Avatar
fab 9 in the chevy, some type of 9 in the gmc i think.
Old 11-28-2010 | 11:02 PM
  #306
james8997's Avatar
i cant help to laugh at someof your post
he will be fine...as long as hes using a strong carrier, gears, etc. the G80 really gave the 10 bolts a bad rep. in higher HP apps, when you launch, (and IF it hooks) the axle tubes will want to 'flex'(the outter axle tubes) and that will break something. with some bracing, good carrier, and properly setup gears, a 10 bolt CAN live
Old 11-29-2010 | 01:10 AM
  #307
Blown06's Avatar
8 Second Truck Club
Do share. Where else am I lacking...............lol
Old 11-29-2010 | 06:24 PM
  #308
MADMAN's Avatar
Head Fabricator
I have drawings already done for a 9" IF we break this one. I can guarantee you it will hook so we will see.
Old 11-29-2010 | 08:24 PM
  #309
Flaco's Avatar
8 Second Club
on the gmc, i am running a stock diff with a Eaton locker and stock axles with leafs and caltracs...it been a best of 1.40 of the foot break with 12 psi launch and 1.37 off the t-brake with 8 psi launch...dont want to leave harder off the t-brake as i feel it will let go
the chevy has a Fab 9 with ladder bars and 40 spline axles
Old 11-29-2010 | 08:39 PM
  #310
262_NBS's Avatar
For Blown06:
since you've had the entire dash harness apart, maybe you could answer a question for me.
Is the power door harness/wiring loomed with the rest of the dash harness or are they seperate? I am trying to determine if I need to swap an entire dash harness when I convert to power windows/locks/mirrors......or if I can just transfer the needed wiring and pinouts to the BCM and door harness junctions on either side of the dash.
thanks for your time
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
