Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 02-05-2011 | 06:58 PM
  #371
custm2500's Avatar
Ph.D. in HUBRIS
Did you boil your side mirror?
Old 02-05-2011 | 07:04 PM
  #372
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Swap to some work truck manual mirrors, problem solved.
Old 02-05-2011 | 09:47 PM
  #373
brent5631's Avatar
Did you try and make coffee in there or something?
Old 02-06-2011 | 01:00 AM
  #374
1SlowHoe's Avatar
Destroyer of Transmissions
Have you opened up the mirror? Whatever did that (seems like heat) probably melted the motor wires together or apart or who knows. That could throw some crazy voltage problems at you. At least unplug the harness to that mirror and see what happens
Old 02-06-2011 | 02:00 AM
  #375
ShredSled's Avatar
that sounds like a logical place to start. and while you're in there try to take notes on how exactly your mirror pours guinness in itself, because I could use some of those!
Old 02-06-2011 | 03:01 AM
  #376
Blown06's Avatar
8 Second Truck Club
I started pouring over some wiring diagrams, then started pouring down some alcohol.
Alcohol: 1
Me: 0
Old 02-06-2011 | 05:58 AM
  #377
custm2500's Avatar
Ph.D. in HUBRIS
Maybe you will fall and smack your head and have a vision of the problem!! See alcohol does solve problems.
Old 02-06-2011 | 11:53 AM
  #378
1989k1500's Avatar
Those are probably heated mirrors huh? Looks like it got too hot.
Old 02-08-2011 | 12:57 AM
  #379
Blown06's Avatar
8 Second Truck Club
I'm at a loss on this one. Been checking a few things and I can't find anything wrong other than it doesn't work.
I might be forced to start over with new harnesses and test it as I remove wires. Would be nice to get the harnesses from a truck with fewer options to start with.
Old 02-11-2011 | 09:30 PM
  #380
Blown06's Avatar
8 Second Truck Club
this post was dumb
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
