Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 04-28-2011 | 08:33 AM
  #431
bigboy576103's Avatar
Cool! So for the lights n accessories did u use the factory steering column for the turn signal ignition ect. I'm assuming u will have no more ac or heat now? This is really interesting stuff keep up the good work man
Old 04-29-2011 | 12:34 AM
  #432
Blown06's Avatar
8 Second Truck Club
Factory steering column is in it but I won't have any signals hooked up for now. Simple lights for DRL, Park, Hi, Low and fog and rear park/brake to get me back on the road. I might end up with the turn signals later we'll see. Ignition will be turned on via switch in the dash and push button start.
Old 05-10-2011 | 12:00 AM
  #433
Blown06's Avatar
8 Second Truck Club
Finally got my motor sold so I went and dropped off some parts at the machine shop today. It's gonna be a budget build but should still run better than the 346 and should work a little better with the F2 as well.
6.0 block, half-filled, studded mains and heads
Eagle 4.100 crank, double keyed
Eagle 6.125 rods
Diamond 4.030 pistons shooting for around 9.5:1 compression
245cc Edelbrocks from WCCH
That'll make it 418 ci, waiting for final flow numbers on the heads and a confirmed compression ratio to decide on the cam.
Old 05-10-2011 | 01:13 AM
  #434
mike06tork's Avatar
engine combo sounds good.. cant wait to see this F2 in action, i belive its the first F2 procharged 99+ silverado in the nation right?
Old 05-10-2011 | 03:23 AM
  #435
pewterliftedz's Avatar
ohh man she's getting closer and closer to being on the road..
Old 05-10-2011 | 07:24 AM
  #436
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Good luck with that stroke in that block with that kind of power. That's too long of a stroke for that block and rods IMO.
Old 05-11-2011 | 12:28 AM
  #437
Blown06's Avatar
8 Second Truck Club
I believe so. Your not doing to shabby yourself.
I was waiting for this comment.
The only con's of this crank/block combo are ones that I'm really not concerned with (slight oil consumption, and long term durability).
Really the goal here was engine volume to help with what is likely going to be mythical boost numbers for the 4-bolt world.
My last combo was an over achiever beyond belief, and did a lot of things most said would never work, so if this combo ends up even slightly as good, look out!
Old 05-11-2011 | 06:36 AM
  #438
blown02408's Avatar
02 w/ lowest mileage 2800
I believe Low LSX is going to be running an F2 also, so let the race begin, lol. I need to get to work......
Old 05-11-2011 | 08:32 PM
  #439
1slow01Z71's Avatar
Good luck to you, two motors later with that combo and thousands of dollars later I still didn't have a good running motor.
Old 05-12-2011 | 01:15 AM
  #440
Blown06's Avatar
8 Second Truck Club
We'll see what happens.
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
