Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
#442
Other than getting ripped up on tech and the bullet, not much.
My engine builder is a little backed up right now. I'm not looking to start another bs 4.100" haters convention, but I did talk to him yesterday and he seems to think he has a handle on a piston design for the 4.100" stroke crank. So we'll see. The way others talk, I should probably go ahead and get started on another engine as well. lol.
#446
The 4.1 crank was made to use a longer rod and for low revving na engines. That crank would be ok in an aluminum block that has a longer sleeve and will give better piston stability at BDC.
#447
Why do you call it a hates convention when people with real world experience with the questions you're asking say its a bad idea. Je and wiseco made my pistons and neither worked. Hopefully they've made some improvements over the last couple of years. I wonder who is willing to build you a 4.1 motor knowing how hard you're going to push it? The compression height alone on that piston is enough not to run it on big boost much less the horrible rod angle, excessive bearing wear etc. Maybe you will get lucky since you don't drive your truck but then again both of my motors had less than 5000 on them before I pulled them out.
The purpose of my posts on tech and the bullet where to find out if anyone had any success with the combo and what they did to fix any of the "known" issues with that combo. I wasn't looking to start a pissing match, but people just get so worked up. I was just trying to start friendly discussion, instead it was like "your engine builder is dumb", "your dumb", "why are posting", etc.
#448
Blown06, I have watched your build with great enthusiasm.
FWIW, 1slow was offering an opinion... a real world one at that. You were waiting for someone to make a comment about the crank - post 438. Looks like your being a little defensive right out of the gate. Its all good though. We're all here waiting for that kick *** truck of yours to haul some groceries!
Lets get the thread back on track
Bill
Bill
#449
Bill
Bill
#450
Please don't misunderstand me. I appreciated the comments from the people who have actually had the combo, whether the input was positive or negative. The hate convention remark was aimed at those who are just retyping something they read on the internet and offer no real substance to a technical related thread. Geez, just cause I have my mind set on doing something doesn't mean we can talk about it.
If you're dead set on that stroke atleast put it in an aluminum block. The instability at BDC is what IMO kills those engines. Both of mine had egg shaped cylinder walls and the skirts were ate up pretty bad.
You have to remember given the same deck height and length of rod the only way to adjust for stroke is in pin placement and pin placement leads to the instability. Also, a small compression height piston due to the stroke length leads to. Weaker ringlands on big boost. They will be much less resistant to any detonation you will have too due to the short compression height. Whatever you do, make sure the pistons have the widest skirt you can possibly get. Brian Nutter from wiseco designed my last pistons, and a very reputable engine builder built the longblock and they failed too thus my stance on not putting much faith in the "professionals". After my own research I figured out what the problem was.
I sincerely hope you get a combo that works I just think its going to be difficult to achieve that given how hard I know you're going to run that engine.
