Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
Old 10-20-2012 | 02:20 AM
  #621
ak2007r6's Avatar
Not sure how I ever missed this build thread. Amazing build! In for more progress
Old 10-20-2012 | 06:40 AM
  #622
custm2500's Avatar
Ph.D. in HUBRIS
They aren't that much differant are they!? yes I noticed from your first post.
Do you have an engine?
Old 10-21-2012 | 02:25 PM
  #623
FarmTruc's Avatar
Performance Trucks Sponsor
Ya I meant 14bolt... Waste if time. By bad.
But I think it was read the way I meant.
Old 10-21-2012 | 04:43 PM
  #624
JoeyGC5's Avatar
Engine updates?
Old 10-22-2012 | 12:22 AM
  #625
Blown06's Avatar
8 Second Truck Club
I didn't get a chance to go by there on Friday due to work ****. I'll pick it up this week. Whats another week after it has been this long?
Old 10-26-2012 | 12:36 AM
  #626
Blown06's Avatar
8 Second Truck Club
Dumb *** Comp fucked the pushrods up. It needs an 8.350" pushrod, which is what they sent. Problem is, they measure 8.370". This thing just barely fits together with the longer valves and the Crower shaft mount rockers. It can't be any longer than 8.350". So new pushrods will be here Monday. Hopefully they work.
Old 10-26-2012 | 12:43 AM
  #627
Atomic's Avatar
I have a gauge for that
Is this still the 418 or did it change since page 22?
Thats the longest pushrod ive heard of being used in an LS....or maybe I dont get out enough. You sure you meant 8.xxx and not 7.xxx?
Old 10-27-2012 | 12:57 AM
  #628
Blown06's Avatar
8 Second Truck Club
Yea, its 8.350". This thing uses a much longer valve to accommodate install height and spring pressure required for the solid roller. Therefore it needs a really long pushrod. The intake lift is .750+.
Its a 408.
Old 10-27-2012 | 09:17 AM
  #629
1989k1500's Avatar
Hopefully they can get you squared away Monday.
After you get the engine back how long before you can have this thing running?
The pushrods in my friends Warhawk are around 9" long and diameter is 7/16 intake and 9/16 exhaust.
Old 10-27-2012 | 11:57 PM
  #630
Blown06's Avatar
8 Second Truck Club
Well the truck is back on the ground. Front and rear suspension under it for good. All the brake lines are plumbed. I need to throw the motor in it and carry it back to madman one last time. He is gonna install the wheel tubs, redo the trans crossmember for the T400, install a shifter and make sure the new rear is squared up.
Once I get it back, its a matter of wiring the holley dominator, plumbing it and it'll be ready to rock. Of course there are some small things like cold side piping, putting the interior back in etc....
I'm thinking 3-4 weeks once I get it back from madman. I'm guessing it won't be at his shop more than 1-2 weeks once I get it to him.
Quick Reply: Blown06-New Build: Cage, 4-Link, Cog Drive, + Too Much More
