Blown06 Suspension/Drivetrain Project: 4/6 Drop, QA-1's, 5-Lug, Bogarts, Long-bars
#172
Thanks.
#173
Don't mean to bump threads, I just wanted to give a quick update on how the suspension is working. I still don't have the torque-arm on yet, so nothing has changed.
It went 1.5705 in the 60' yesterday. I'm beginning to wonder if this torque-arm is going to actually hurt it. I don't like going backwards.
#174
With your flip i dont see how some sort of bar wouldnt help whether it be caltracs or a torque arm, and you already have everything for the bar..
For some reason if it doesnt work, just ditch it.. but i would at least give it a couple times out before ditching it.
Does it feel like your truck is hooking pretty good now, little to no spin?(looks to leave pretty good on that shaky video lol) With those big slicks and a half decent track id imagine it cant be to bad, and some type of bar would help transfer that traction.
get that 60 down in the consistent 1.45range, who knows that might be good for some 10.20s up top in similar conditions..?
Im bored just thought id throw my 2cents in on the matter..
#177
LOL.............something, to avoid hitting someone. I have a feeling if it was someone I'd be in jail for murder. I got into an altercation with someone I didn't want to hit and hit something else instead in order to diffuse the situation. Alcohol was involved and I feel like a complete fool for loosing my temper the way I did. Lesson learned. Was it worth it......Not in a million years.
Back to the truck, I wanna make sure my pinion angle is perfect before building the torque arm. I know how to measure pinion angle, but I'm wondering about the leveling of the motor and trans. When I originally built my trans x-member, I have a feeling I didn't build it tall enough and the motor seems to angle back a little bit. I would like to redo the x-member to get the motor/trans perfectly level in the truck however I don't know a whole lot about building/setting up race cars and was wondering if level is ideal. If so, what do I need to make sure it's level with? The frame rails, the ground at ride height, the rocker panels, an imaginary line parrallel with the center of the front hub and rear axle, etc......Even if the motor needs to be at a specific angle, what do I measure that angle off of? Should I call some chassis builders? Any opinions?
#178
Formerly darynC-10/23/10
okay , i have a question..... how does the truck feel " stiffness" wise?
was there a noticeable reduction in drivetrain slack/ axle wrap?
i am looking to do ALMOST the same thing as you.... except my tq arm will be a little bit different, shocks will be in pretty much the same location.... and maybe swap the leaf springs out for some control arms and a panhard bar....
with having a tq arm and coil over shocks.... there is really no use for leafs i would say!
#179
#180
i know your probably right!!!, but luckily for me MADMAN lives right down the rd from me... ill be paying a visit to him monday morning , and we will brainstorm on what setup would suit my needs... truck isnt a 100% full blown track vehicle, its mainly a street / play truck, hence the t56 ! but i need something thats going to give me a good foot on the ground with the tall gearing. hell i somehow managed to wheel hop 4th gear at 80 mph last night!!! dont tell me that wasnt a wild ride!
