Bonjie 2011 Build begins.. sort of
#51
good new is my cam is already at the shop
the block is already at the shop
oill pump, rockers, ls2 timing chain set is on its way
heads later this week if i can find a box an 8 more LS7 lifters.. GRRRR
crank is getting ordered today but the probe pistons are on 6 week back order.
#52
Mike it's good to see your getting close to doing your swap,I have been wrenching on my truck some lately and hope to do the initial fire up the weekend after st,patty's day! If everything shows up on time!
#55
It's been a lot of fab work and all of that takes a lot of time,we made a custon blower bracket for the F1R with the cog drive that works with the truck accesories,relocated the alternator and power steering pump,fabbed up brackets for my 3000 cfm A2W intercooler and 10gal ice box with tranny cooler inside,relocated the battery and washer fluid tank,it's just been a long process!
#60
they are your heads now Mike, so you give what ever info you'd like. Besides i've posted the posted the flow numbers on those heads a bunch of times, they're pretty good so i wasn't going to hide it
