Bonjie 2011 Build begins.. sort of
#84
Yes Sir it is.I swapped to a different cam (pat g spec),went with the heads in my sig,yella terra rockers. it's been a long process. ended up doing a 4l80 swap,ripped the whole fuel system out and upgraded to 10-an feed and 8-an return,pusher fans behind the grille,A2w intercooler with 10 gal ice box,4" aluminum charge pipe,custom blower bracket for cog setup,it's geting really close though! I will keep you posted.
#85
just kiddin.. brent i wanna see that beast running.. maybe bring it over to help with my swap!
#86
definately! waiting for the brackets to come back from the powdercoater,and the ice tank should ship out tomorrow or friday,then all I have to do is some wiring,a little plumbing,and weld up the full stainless exhaust and it's light my fire time!
#88
NO WAY! what is going on with it? The 4l80 swap is really not that hard at all Mike! if you get the parts we can do it in a weekend! No more troubles!!! I can make you a crossmember and tranny lines and I have all the spec's for the driveshaft's,and the shop I got them from in St. Charles had them done the SAME DAY! A little wiring and a segment swap and it's all done!
#89
brent.. ugh.. would be nice, but i physically cannot lay under the truck anymore.. im going to see a pain doc today. i have degenerative disk disease in my back..so the "we" .. becomes "you" lol.
i got the tranny in the shop now. ill have it back by 5 pm tomorrow.. 3 yr unlimited warranty on it.. after i finish the 408 project, if i find i need more.. then ill talk 80e
