boostdsierra FINALLY becomes a Boosted Sierra!!
The stock axles are pretty dang strong. The guy with the 9 sec. ext cab said he didn't start bending the stock axles until he got into the 9 second range. That being said, those are the same axles I am running. My only confusion is why the studs Moser sent are so damn short.
That was the very first thing I noticed when I opened the box!!
I haven't had a chance to test fit them yet though....
Maybe you can clarify that with Moser.
Since you are still 6 lug, and presumably will run stock wheels, this will not be an issue since the wheels should be HUBcentric. However, on my 5 lug setup, the wheels are LUGcentric and the short studs makes it a royal PITA to get the lug nuts on.
Another point on the wheel studs is at some point of speed you legally have to have long studs to make track officials happy. Never heard of them cracking down on anyone and don't know the speed, or E.T. but something to look into before you have to swap studs later down the road and it is together.
The build look killer so far!!!!
Thanks for the input!
I plan to give Moser a call today and see what they say, I'll post up the solution when I have it!
