Budget Build Thread - Help
Old 04-06-2013 | 09:03 PM
  #91
idahoblkss's Avatar
Yeah lil nipple off the passenger side cut it then attach to it.
Old 04-06-2013 | 10:10 PM
  #92
03 BLKTAHOE's Avatar
Thanks guys so I can just hook straight to my vaccum block then right? Thanks
Old 04-07-2013 | 10:14 PM
  #93
I'm ordering my tune tomorrow and was wondering how you guys keep from going lean or to rich? Will it be in the tune? I need to get a wideband gauge and I found one that has several failsafe in it that you set like pulling timing or a setting for a boost level. This one works with Efi live but im getting Hptuners so I need to find another one or if you guys got any ideas?
AEM Performance Electronics Wideband Air Fuel Failsafe Gauge - Wideband O2 UEGO, Water/Methanol, Stand Alone Engine Management, Piggyback F/IC, Tru Boost Controller, Gauges, Automotive Performance Electronics
Old 04-13-2013 | 01:27 PM
  #94
I need some help im trying to install my AEM wideband but I can't figure out where to connect the white wire. I did a little research and can across this thread below that says connect it to the IEO#1 but I dont know what that means can some one please help? Thanks
To log in HPtuners, Once your wideband is installed, Power Ground..etc.*Hook the white wire into IEO #1 (top*pin) The Blue is un used. Open VCM Scanner, Click on Table Display, At the the bottum Right click on "IEO Input #1" Click Insert, open Wideband 02, Scroll down to "wideband 02-AEM, Doubble click then save config and your done.*That will get you up and running.. tuning with
Old 04-13-2013 | 03:24 PM
  #95
oakley6575's Avatar
Hopefully you ordered the pro version of HPT. If you did, the wire wire goes into the first input in the usb to OBD2 connector.
Old 04-14-2013 | 09:21 PM
  #96
Thanks oakley I did order the pro version should be here Wednesday.
Old 04-19-2013 | 10:03 AM
  #97
Racetronix - need some help I bought a aeromotive stealth 340 part number 11169 from Summit Racing but my mechanic sad that I cannot put a pump inside the sending unit I need to buy the whole unit as one. Im going to return the pump and would like to get the right one could somebody give me a part number to one that will work? Im not sure also on center flow, outer flow. etc.. they said they have 3 other Aeromotives but not sure on center flow side flow etc could some tell me which one I have.
I found this one if it would work but I would have to order and wait for it in the mail.
Old 04-19-2013 | 10:42 AM
  #98
My trucks a 2000 sierra 5.3 auto 2wd if that helps
Old 05-18-2013 | 07:47 PM
  #99
Well I didnt really get to enjoy my boosted truck long. It was running like crap so my mechanic came over and I found out that it has "crank shaft end play" basically it could be the crank or the bearing or both so im thinking the best route is to look for short block.
I have a few question wheres a good place to get a short block?
Also could I get a 6.0 short block and just throw my 862 heads on and just get it tuned but keep the same computer?
Old 05-18-2013 | 08:13 PM
  #100
GMCtrk's Avatar
Your mechanic was wrong about not being able to install that aeromotive fuel pump.
What exactly is your current problem?
