Budget Build Thread - Help
Old 09-04-2012 | 05:55 PM
  #21
Atomic's Avatar
I have a gauge for that
The LS2 chain is 2mm wider I think, so its a lot stronger and less prone to stretch.
Old 09-04-2012 | 10:45 PM
  #22
03 BLKTAHOE's Avatar
Can any of you guys confirm if this is the right bolts that I need? I'm not sure why it comes with 34 bolts there are only 15 bolts per head. Im not sure what the other 4 bolts are for?
http://item.mobileweb.ebay.com/viewi...656&cmd=VIDESC
Old 09-04-2012 | 11:43 PM
  #23
Does it matter that the ls9 gaskets have a larger bore size?
Old 09-04-2012 | 11:56 PM
  #24
Atomic's Avatar
Those are bolts, I would really go with the studs if you want to go aftermarket.
LS9 gaskets are fine even with the larger bore.
Old 09-08-2012 | 11:36 PM
  #25
I came across this thread saying that if you have the notch in your heads you CAN'T run any thing but the stock graphite gasket. I was planning on running the LS9 gasket has any body run the LS9 gasket with the notch in the heads?
https://www.performancetrucks.net/fo...2002-a-493365/
Old 09-08-2012 | 11:44 PM
  #26
1FastBrick's Avatar
Custm2500's Rude Friend
The bolts referenced above is just a generic picture.
The gasket info is correct if you have the notch. I believe there is even a Gm bulletin about it.
Old 09-09-2012 | 12:09 AM
  #27
I do have the notch in the heads so I can't run the ls9 gasket right?
Old 09-09-2012 | 12:48 AM
  #28
1FastBrick's Avatar
Probably not. Either get another set of heads or use a graphite gasket.
Old 09-09-2012 | 08:57 PM
  #29
Well I finally got the motor broke down and most parts cleaned. I’ve got a ton of gaskets, water pump, oil pump, knock sensors, timing chain and countless other stuff on order. Once I found out that my heads are the old style with the notch in them it kind of put a stop from me ordering the Ls9 gasket and head studs.
Has anybody found a better gasket that there running boost in the 15# range and up beside the stock one? I’ve got an upper gasket set that includes the head gaskets but I want to make sure nobody recommends any other gasket.
[IMG][/IMG]
[IMG][/IMG]
I had the heads cleaned, milled and a valve job done with new seals.
[IMG][/IMG]
Old 09-09-2012 | 09:07 PM
  #30
Just to be clear my heads are the bottom ones with the circled notch I cant run the Ls9 gasket it will leak. Are any of you running this same heads? Do you recommend a certain gasket? Im planning on running 15# of boost or more.
[IMG][/IMG]
