Budget Build Thread - Help
Old 01-13-2013 | 09:15 PM
  #61
03 BLKTAHOE's Avatar
Nothing is better than the factory fans IMO.
I cant use the clutch fan it will be in the way of the turbo piping
Old 01-13-2013 | 09:30 PM
  #62
oakley6575's Avatar
I'm talking about the factory electric fans.
Old 01-13-2013 | 09:31 PM
  #63
Just some progress pics I decided to mount the vacuum block to the ground for the hood
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I have the 862 casting and i already dumped $250 in getting the heads reworked when i found out that i couldnt use the better LS9 gaskets. So i decided to have them welded. If you look closely you can see where the filled in the dip. I've figure i would give it a try.
[IMG][/IMG]
The nicer Ls9 gaskets...
[IMG][/IMG]
[IMG][/IMG]
Old 01-13-2013 | 09:42 PM
  #64
I having problems with the Ac line coming out of the Evaporator core it was sitting on the down pipe for the turbo.
[IMG][/IMG]
I had the ac line reworked to atleast get it off the down pipe but i need to have them take som slack out of the hose and make the last bend straight
[IMG][/IMG]
AS YOU CAN SEE I NEED TO HAVE IT RE DONE
[IMG][/IMG]
Old 01-13-2013 | 09:46 PM
  #65
I need to get a efan now I what to go with from what am been reading the Ls1 route but not really sure on which one to get. Can any of you guys explain this more? I read that you need a separate wire harrness and a tune that turns on the efan option?
Old 01-13-2013 | 09:50 PM
  #66
oakley6575's Avatar
What size radiator do you have? If you have the smaller one and go with the ls1 fans, you might regret it later. I would upgrade to the 34" radiator and factory fans.
Old 01-18-2013 | 08:00 PM
  #67
I need a little help when I took my motor I lost a part and was hopeing one of you guys could tell me what it is that I lost so I can buy one. Video link below Thanks
[IMG][/IMG]
Can somebody please look at there truck and see if they have the same plug from there wiring harness in the same area that plugs into what looks like a coke can size but black? My truck is a 2000 Gmc Sierra 1500 2wd. Thank you
Old 01-19-2013 | 01:47 PM
  #68
Anybody could please just look under your head and take a pic? I then can show the dealership or part store and they should be able to tell me what it is.
Thanks
Old 01-19-2013 | 08:30 PM
  #69
1FastBrick's Avatar
Custm2500's Rude Friend
The pig tail you show in the video looks like the pig tail for the Coolant temp sensor that is screwed into the head just behind the power steering pump.
The bracket in the Video from the pump bolts directly to the Block and underneath that is a Ground wire that bolts to the block.
Old 01-19-2013 | 08:50 PM
  #70
Thanks I'll stop by the parts store and see if that's what I need. I hope so I've been looking for ever. Thanks once again!
