Budget Build Thread - Help
#71
Thanks 1FASTBRICK i didnt know I needed a coolant sensor but what was weird is when I went to put it in there was a plug there. Do any of you know why it would have a plug?
[IMG][/IMG]
Do any of you know why it would be plugged?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
#72
Also my last three things left to finish the build are Exhaust, tune and efan.
I came across Nelson performance and I would like to order there wire harrness for the LS1 fbody but not sure what is an fbody. When you look up Ls1 efan on ebay several pop up but I cant find one that says fbody. Can someone explain what fbody means?
THANKS
THANKS
#73
Yes, you put the heads on back wards. Doesn't matter though as there symmetrical. Reach around the rear port on the passenger exhaust manifold and you will find were the plug should be...
In other words that head was originally on the Pass side and vise a versa.
#74
I came across Nelson performance and I would like to order there wire harrness for the LS1 fbody but not sure what is an fbody. When you look up Ls1 efan n ebay several pop up but I cant find one that says fbody. Can someone explain what fbody means?
THANKS
THANKS
#75
Thanks again 1fastbrick I'll be sure to put the plug back in the other head and thanks about the fbody now I know what to look for. It's funny though because when I was putting the heads on I was wondering if there was a right and left to the heads good thing there interchangeable.
Once again thanks!
#76
Once again thanks!
Once again thanks!
Glad I could help!!!
#77
I found this ad on eBay for the efan it's says it come with the wire but does this meAn I dont need a wire harrness? I'm assuming I still do? There is a efan cheaper but it doesn't come with wiring. Which one should I get?
98 02 Corvette Camaro Firebird LS1 Electric Dual Fans with Wiring 99 00 01 Swap | eBay
#78
I have a gauge for that
It looks like that one just has the fan plugs, not the whole wiring harness. The value of two of those plugs is about $15, but you will still need the rest of the wiring harness including the relays. I would get the cheapest bare fans you can find then purchase a complete harness from someone.
#80
