bye bye 112....hello 1900
#94
they are GM 3.4 V6 manifold studs...About $1.50 each at the dealer. grade 9.8 and fit the LS heads perfectly...plus a 5mm head for easy install. i am using all metal lock nuts. when i took off the shorties, they were still nice and tight after a year.
#96
Studs: 10182325 QTY: 12
Nuts: 11517031 QTY: 12
They come in packs of 5, so we will need 3 packs. Using studs will make putting the headers on some much freaking easier. I can't tell you the frustration I've had at times trying to hold the header flange up, lining up the gasket, and sticking the first bolt in all at the same time...
