bye bye 112....hello 1900
Old 02-06-2009, 09:17 PM
  #61
EVILGMC's Avatar
TVS going on tomorrow!!!
Old 02-06-2009, 10:54 PM
  #62
BuiltNotBought's Avatar
Nice!
Old 02-06-2009, 11:20 PM
  #63
zippy's Avatar
Originally Posted by EVILGMC
shooting for 10psi with this one. was at 7.5 psi with the 2.8 pulley on my 112 and it made 490hp at the tires thru an 80e.
going to start off mello with a 3.3 pulley and take from there (3.0 or 2.8): 60lb injectors, 103mm MAF, 2 bar, LTs, true duals all ordered. alky control considered....and possibly re-gear from 4:10 back to 3:73
Why spend money on an expensive maf if you are going 2 bar?
Old 02-06-2009, 11:39 PM
  #64
EVILGMC's Avatar
so i have a better chance at passing smog at the end of the year....plus i got the 103mm MAF hosing, pigtail, LS3 MAF card and 2 bar MAP for $150 delivered!
Old 02-07-2009, 10:58 PM
  #65
EVILGMC's Avatar
well toady i got the blower on...but then it came back off. have some clearance issues to address and then its time to fab brackets for the NNBS heat exchanger. you can see the phenolic spacers that bill was needing today. even with these, i dont think it will clear the vent in my LS6 valley cover. the alternator bracket also need to be massaged. also, the evap purge valve bracket interferes with the coils on my truck because the return fuel system has a larger pressure regulator manifold than the returnless styles. i was able to mount the NNBS intercooler reservoir today...it will do until my aluminum one gets here. taking my time and having fun...also helping out around the shop with all the other projects they have.
Old 02-07-2009, 11:02 PM
  #66
Looks Awsome!
Old 02-07-2009, 11:15 PM
  #67
KySilverado's Avatar
You guys are killing me with the new hardware. If you come back with track times setting the world on fire I'm really going to be motivated.
Looks great!
Old 02-07-2009, 11:18 PM
  #68
2nd fastest 5.3 ECSB
trever1t's Avatar
Rearranged your pics to fit the forum Patrick. Looks great, that is not the heat exchanger that came with the kit, is it?
Old 02-08-2009, 12:11 AM
  #69
SimpleManLance's Avatar
looks like your off to a good start.
do you have any more pictures of how you mounted that heat exchanger? i want one that size for my 122.
Old 02-08-2009, 12:53 AM
  #70
EVILGMC's Avatar
that is the heat exchanger for the 08-09 trucks. i am going to make brackets this upcoming week.
Quick Reply: bye bye 112....hello 1900
