A completely different kind of project.
Having no IAC will just not let it idle perfectly in all weather conditions. I will only be running the truck in warmer weather so 15-30 differance won't effect the idle speed much. Worst case I have to pop the hood and adjust the idle screw if it is really high or low at any given time. I really doubt I will ever have to change it. Just as the stock TB has a idlescrew i will do the same. Only thing is I will have to have my TB open just slightly at idle to let a tiny bit of air through as apposed to the IAC letting the perfect amount through.
Other fine examples of your work.
sidepipes:
http://i111.photobucket.com/albums/n...0217001039.jpg
backup camera first edition:
http://i111.photobucket.com/albums/n...1-09223933.jpg
backup camera final product:
http://i111.photobucket.com/albums/n...1-17172448.jpg
cooked bed:
http://i111.photobucket.com/albums/n...x/IMAG0115.jpg
bedcover:
https://ls1tech.com/affiliates/truck...d.php?t=470798
removing front brakes to save weight:
https://ls1tech.com/affiliates/truck...d.php?t=470892
sidepipes:
cooked bed:
bedcover:
Outlawz the side pipes were sitting on the lift and Jack stands, simply sitting there to get an idea how they look. So if you want to keep talking **** you might want to make your self look like an idiot posting a pic that has nothing but approximate placement in common with the final product.
You continue to show you idiocy with talking about my "crooked bed". Obviously you are too ignorant to understand reality.
You may not like how my screen was set up but I was happy with it. I have a larger screen that is square and getting mounted to your liking.
sidepipes:
cooked bed:
bedcover:
sidepipes:
cooked bed:
bedcover:
Yeah, sometimes you just have to bite the bullet and pay to get it done right/get the right parts.
