Component &Tweeter Installation
Audiobahn ABC600J Components Install-
Pretty heft magnet, They sound really good.
Stock Door Panel
Back of door panel with tweeter mounted before i removed the white brace for more room for the crossover
With Brace Removed
Door Panel With Audiobahn Tweeter mounted
Crossover mounted on the door(i taped off all of the holes i've got 100 sq feet of FatMat on the Way)
Door with Crossover and 6.5 speaker mounted
Finished with Door Panel on truck
Tweeter Install-
Stock Pillar with Factory Tweeter
I trimmed the back side of the stock tweeter cover for fitment of the new ones
Tweeter Hooked up to factory harness for plug and play install
Installed and hot glued for better support in factory pillar
Finsihed back side
Looks Stock!
My Truck-2011 ECSB 6.2 6L80E!
Stock Door Panel
With Brace Removed
Tweeter Install-
Finsihed back side
Looks Stock!
Seems like a bad idea to add the power of the components and take out the brace for the door panel.
Everything else looks sweet!
Do you have amps powering these yet?
No amp on the components yet, still debating on what to power them with, the brace removal didn't seem to make and difference in the flexibility of the panel
So you are running components on radio power? If so you would have had a much better upgrade to power the stocks then put the components in after the amp.
Still should be great improvement over the factory set up and will only get better with time.
Mossyoakglock
07-17-2015 08:30 AM
