CTTAndy's Suburban Work Truck
Old 12-23-2011, 01:04 AM
  #161
cttandy's Avatar
My trans is supposed to be rebuilt, but I have reasons to question that. Just doesn't seem right to me, despite have a nice silver paint job on it. Could be that the motor is so screwed up that it messes with the trans, but I'd rather not take that chance.
Old 12-23-2011, 06:13 AM
  #162
gmstrong's Avatar
that brown truck looks so much better with those rims and smaller tires.
Old 12-23-2011, 10:41 AM
  #163
cttandy's Avatar
Not sure which way your talking about. It had many difference versions. My favorite was the narrow 35's on the 18 inch wheels.
Old 12-23-2011, 06:03 PM
  #164
cttandy's Avatar
Called my buddy tonight, we are trading the 2wd trans for a 4wd trans. So that is no longer a concern.
Parts list needed
98-99 Cruise Control Cable - got it
F-body accelerator cable
Non-egr exhaust manifolds - got them - huge thanks to Andrew383
Non-egr intake or http://www.summitracing.com/parts/NAL-12558346/
Stock 99-02 truck exhaust y pipe with cat's
Stock breather assembly - got part of it - huge thanks to Andrew383
MAF
drivers side battery mount - got it
Bolts for all the drive accessories and engine/trans
99-02 Upper Radiator hose
04-newer cooling fans
ECM
Power Steering lines - picked up a power steering cool with all the necessary lines, still wanting to convert to a hydroboost
Fuse/Relay block from a junkyard vehicle. - found something new to use
Airtex 110-E3270 - Airtex Electric In-Tank Fuel Pumps - Overview - SummitRacing.com purchased
Summit Racing SUM-2200077B - Summit Racing® AN to Tube Adapter Fittings - Overview - SummitRacing.com
Summit Racing SUM-220690B - Summit Racing® Hose Ends - Overview - SummitRacing.com
Trans-Dapt Performance Products 4595 - Trans-Dapt Performance Engine Swap Motor Mounts - Overview - SummitRacing.com Purchased
Wix Filters 495-33737 - WIX Filters Fuel Filters - Overview - SummitRacing.com
Summit Racing SUM-G1001 - Summit Racing® Auto Flex Hose - Overview - SummitRacing.com
That is the list of known's right now I am sure it will grow.
Old 12-23-2011, 06:36 PM
  #165
cttandy's Avatar
Some car **** purchased for the s-10 build that I just sold. It is sitting in a friend's shop, need to pick it up and bring it home.
Old 12-25-2011, 01:45 AM
  #166
cttandy's Avatar
Ok, BIG question.
On the newer trucks, there is a tow/haul button on the end of the shifter. I pull a trailer a lot and frequently used this on my 03 XL, so I really want to be able to use something like this in my Burb. Can I wire up a momentary switch and LED light in my dash to activate the tow mode.
I know I can just have the tune changed to run like that all the time, but I would prefer not to do that. I'd like to keep that nice shift unloaded.
Old 12-25-2011, 02:06 AM
  #167
13 Second Truck Club
A Low Dime's Avatar
I added the Silverado Tow/Haul shift in my 2000 S10 with no issues, its just held in with one bolt. All it needs is the pin ran to the computer.
Im pretty sure a momentary switch will work, an on/off wont, because the PCM pin hooked to the shifter is just a quick "ground" flash to change trans tables.
Old 12-25-2011, 02:46 AM
  #168
cttandy's Avatar
Just found this from my cell phone. Looks to have my answer though.
http://www.hptuners.com/FORUM/showthread.php?t=8887
Old 12-25-2011, 11:44 AM
  #169
cttandy's Avatar
Waiting for family to show up for lunch, have some time to kill. My reading last night tells me there is a PIN-71 or something like that, that needs a momentary switched ground to activate the tow/haul mode.
I also found out, that with the same switched ground, to PIN-31 or whatever, gives me the ability to manually shift my trans. I don't want this for racing, but I could see a big advantage for towing and possibly even some of my buddies doing truck pulls. Something tells me that this might already be in use on 4x4's. Possibly connected some how to low range in the TC.
I am going to go talk to an electronic wizard friend of mine. I am hoping he can build be a little circuit to activate a LED light using the switched momentary ground. I think I could do it with a relay if I sit down and play with it.
Old 12-25-2011, 12:42 PM
  #170
cttandy's Avatar
I forgot to give 2 updates this summer. The truck now has a pretty nice Sony Cd-player in it with all aftermarket speakers I pulled from a wrecked truck that I parted out. I also finally swapped out my rearview mirror. It fell off going down the road, so I installed a mirror from a 97 Olds Aurora that has auto-dimming and compass.
Quick Reply: CTTAndy's Suburban Work Truck
