CTTAndy's Suburban Work Truck
#72
Had some time, and I got my hitch and tow hooks installed. Nothing particularly hard. Only took 15 minutes for me to get it on by myself using a floor jack.
This came while I was out there
Looks like a nice piece. Hopefully my headers get here pretty quick and I can get it all put on.
#76
Probably so, the stock Y doesn't have pipes as large as this, the O2 is rusted in place, and someone hacked it up pretty good eliminating the cat.
I also liked the fact that the Y is made with the cat. Unlike the stock piece that has the 2 pipes disfigured and merged into one pipe.
#77
trucks looking well as always Andy, keep us informed on the shorties, I got some headers coming soon as well, pretty excited on both our accounts
#78
Thanks guys
I am going to have to keep an eye on it. I lost oil pressure the other day, right before we found the distributor gasket leaking badly. So we replaced the gasket, but I can't remember if we checked the oil again or not. I am pretty sure we forgot. I hope, because 200 miles later I am 2.5 quarts of oil low.
The truck isn't smoking, but there is oil on the top of the transmission and down the back of the block. I pulled one of the spark plugs out of the back of the motor and it had oil on it. It didn't have a lot, so I am not sure if that means there was oil sitting on it when I pulled it out, or if the head gasket is leaking like these TBI trucks are known to do. If it is in fact the head gasket, the whole motor will be coming out. The PO said he just had head gaskets installed, seems to me there might be something else going on causing it.
#79
A bad distributor gasket will leak pretty significantly, enough to cause the oil everywhere you described. If your head gasket was bad, it's a pretty theatrical affair, with smoke and misfiring, dirty coolant and nasty oil, so I don't think it's that. Check your rear main seal too, see how it looks. As to oil on the plugs, just see where the oil is on the threads. Does it go all the way down to where the plug sits in the chamber, or does it stop before the carbon line on the plug threads where it enters the chamber? (if thats clear enough lol) If it stops, usually that means oil got from the outside of the plug and leached on down the threads.
#80
