Dan's RC Revival
#142
arthursc2 (12-16-2021)
#143
Might need to make a separate page on this brake stuff (with more pictures!)
Check this rotor, https://www.rockauto.com/en/moreinfo...t=1896&jsn=500
Found it on this nice forum post all about upgraded rotors,
https://www.pirate4x4.com/threads/bi...ashion.653161/
dantheman1540 (12-17-2021)
#145
You could maybe add a parking brake caliper or do a driveshaft disc/parking brake- but swapping to that rotor, assuming the hat offset and rotor width is good- loses your parking brake
#146
that is a front rotor and therefore incompatible with the drum-in-hat parking brake all of the GMT-800 and 900s (and others) use in the rear
The parking brake was one of the biggest disqualifiers I was running into when looking for something compatible. The biggest thing I came across that should fit is a 13.1" rotor from EBC, for some reason it's only listed for the 2500HD on Summit and not H2s but It ought to fit, just not sure if it's big enough. The downside is it won't ship for 2 months and must be bought in a pair for $350.
#147
On that Pirate4x4 link, they listed a 2006 Ram 3500 rear rotor that could potentially work but it's very difficult to tell the offset from pictures. https://www.summitracing.com/parts/b...3500/year/2006
#148
There are more dimensions on that part here https://www.carid.com/bendix/global-...n-prt5452.html
I don't know if they help:
Rotor Diameter: 352.4mm (13.87")
Rotor Height: 130.9mm (5.15")
Nominal Thickness: 30.1mm (1.19")
Minimum Thickness: 28.4mm (1.12")
Lug Holes Quantity: 8
Lug Holes Size: 17.1mm (0.67")
Bolt Circle: 165.1mm (6.5")
Center Hole Diameter: 123mm (4.84") more details on - https://www.carid.com/bendix/global-...n-prt5452.html
dantheman1540 (12-18-2021)
#150
I would do an AWD conversion if I was to ever do something like that.
