Dan's RC Revival
Old 12-16-2021, 09:46 PM
  #141
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
Originally Posted by dantheman1540
Still needs a line lock thooooo
Old 12-16-2021, 09:50 PM
  #142
dantheman1540's Avatar
Originally Posted by arthursc2
That's a long drawn out way of saying "Arthur was right when he told me the rear brakes were good enough"
Yes but better would be bettererer
Stop you’ll give @1FastBrick PTSD
arthursc2 (12-16-2021)
Old 12-16-2021, 10:16 PM
  #143
silentbravo's Avatar
Might need to make a separate page on this brake stuff (with more pictures!)
Check this rotor, https://www.rockauto.com/en/moreinfo...t=1896&jsn=500
Found it on this nice forum post all about upgraded rotors,
https://www.pirate4x4.com/threads/bi...ashion.653161/
dantheman1540 (12-17-2021)
Old 12-17-2021, 01:07 AM
  #144
makes children cry
_zebra's Avatar
I don't...
But at 1 time I had 10, yes 10 2wd 4L80E's
that's because 2wd is worthless, and everybody outside of FL, TX, & CA are well-aware of that fact
Old 12-17-2021, 04:35 AM
  #145
arthursc2's Avatar
that is a front rotor and therefore incompatible with the drum-in-hat parking brake all of the GMT-800 and 900s (and others) use in the rear
You could maybe add a parking brake caliper or do a driveshaft disc/parking brake- but swapping to that rotor, assuming the hat offset and rotor width is good- loses your parking brake
Old 12-17-2021, 06:35 AM
  #146
The parking brake was one of the biggest disqualifiers I was running into when looking for something compatible. The biggest thing I came across that should fit is a 13.1" rotor from EBC, for some reason it's only listed for the 2500HD on Summit and not H2s but It ought to fit, just not sure if it's big enough. The downside is it won't ship for 2 months and must be bought in a pair for $350.
Old 12-17-2021, 06:53 AM
  #147
On that Pirate4x4 link, they listed a 2006 Ram 3500 rear rotor that could potentially work but it's very difficult to tell the offset from pictures. https://www.summitracing.com/parts/b...3500/year/2006
Old 12-17-2021, 10:02 PM
  #148
There are more dimensions on that part here https://www.carid.com/bendix/global-...n-prt5452.html
I don't know if they help:
Rotor Diameter: 352.4mm (13.87")
Rotor Height: 130.9mm (5.15")
Nominal Thickness: 30.1mm (1.19")
Minimum Thickness: 28.4mm (1.12")
Lug Holes Quantity: 8
Lug Holes Size: 17.1mm (0.67")
Bolt Circle: 165.1mm (6.5")
Center Hole Diameter: 123mm (4.84") more details on - https://www.carid.com/bendix/global-...n-prt5452.html
dantheman1540 (12-18-2021)
Old 12-18-2021, 03:19 AM
  #149
Custm2500's Rude Friend
1FastBrick's Avatar
4x4 conversion is easy. some one listed it on this site already. Cores are still expensive and not easy to find
Old 12-18-2021, 03:20 AM
  #150
shakenfake's Avatar
Received 1,278 Likes on 975 Posts
I would do an AWD conversion if I was to ever do something like that.
Quick Reply: Dan's RC Revival
