Dan's RC Revival
Old 01-09-2022, 09:49 PM
  #251
makes children cry
_zebra's Avatar
oh, i wasn't saying a 1900 was completely useless. shoot, i know a guy who put a little TVS2300 on his built 427 C5 and used 1 3/4" headers... granted, he only made 571hp with 633tq (meaning the top end fell off like Stephanie Adams from a 25th floor window), but he still had a driveable car.
Old 01-10-2022, 07:17 AM
  #252
dantheman1540's Avatar
Wait you have a 427 in Eve?
At this point, I just want boost in my life again.
Old 01-11-2022, 07:10 AM
  #253
makes children cry
_zebra's Avatar
no; mine's still the 346 LS1 & dynoed 650h/630t before adding 3 more psi from my 2300 (and has 1 7/8 headers).
the LS7 was another guy i know.
Old 01-11-2022, 08:39 AM
  #254
Ok that's what I thought, sucks my long tubes are 1 3/4" but oh well a 4" cutout might make up for that.
Old 01-11-2022, 10:26 PM
  #255
makes children cry
_zebra's Avatar
well, you also don't quite need the top end that a car half the weight would prefer.
Old 01-15-2022, 07:05 PM
  #256
Brakes are on and look proper good if I do say so myself. Need to lay out mount and connect the rear axle hardlines and search for the SS flex lines to connect them up so they can be bled. Also need to sort out the parking brakes and hopefully the cables I have will work as they should. I bought what I believe are early NBS RCSB disk brake lines since mine had drums.
What diff juice should I use with the locker? Cheap ole 75-90 with no additive? I plan to run the first round of fluid for less then 1k and change to a synthetic just to help clean out some of the rust and gunk that might be left in it.
The following 2 users liked this post by dantheman1540:
arthursc2 (01-15-2022), RedXray (01-15-2022)
Old 01-15-2022, 07:46 PM
  #257
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Looks good!
You only need the friction modifier if you have clutch packs. A locker is 100% mechanical with no clutch materiel isn't it?
Old 01-15-2022, 08:05 PM
  #258
Thank you! Correct the locker is 100% mechanical so no clutches therefore cheap ole Walmart Supertech 75-90 should be just fine. Maybe get some Mobile 1 full synthetic after break in.
Old 01-15-2022, 09:02 PM
  #259
makes children cry
_zebra's Avatar
i just put some RedLine 75w-90 GL-5 in the H3 and dodge diffs. so far, so good. stuff ain't cheap, but i've heard it's worth it.
also just swapped both trucks out with the RedLine MT90 GL-4 transmission fluid, too. almost eliminated the G56 gear roll-over noise with the Valair dual & SMF.
Old 01-15-2022, 09:21 PM
  #260
arthursc2's Avatar
Received 1,502 Likes on 1,101 Posts
I run the Mobil 1 75/90 LS. I buy it by the case because it is a lot cheaper per bottle that way. I've been really happy with the performance of the oil. Both the Ranger and E-350 had rear diff chatter when I got them- all fresh and smooth now
The Ranger, E-350 (front and rear), C5 and MR2 all have clutch type LSDs in them, so I just put it in the front and rear of the Tahoe
I have a lot of differentials in my life 😂😂 must be why I am so dumb
dantheman1540 (01-16-2022)
Quick Reply: Dan's RC Revival
