Dirty Dan's RCSB 4X4
Old 11-20-2019 | 08:44 PM
  #201
dantheman1540's Avatar
Originally Posted by _zebra
wait... so you're still running the 4.8 flywheel & clutch?
No No No! The 4.8 clutch was nearly non existant and the flywheel had some serious hot spots. The NV4500 clutch I got was just to OEM specs I think it's a LUK. I've already put right at 30k on the nv4500 swap. I never even really broke the clutch in. I remember leaving Smith's off road and matting the throttle in first gear spinning the tires in their lot. It was open header when I left their shop because they didn't have an exhaust bender.
But since they are the same 12in size unless the pressure plate is much different which it likely is. The clutches could be interchangeable.
Unless I'm missing something else very obvious.
Old 11-20-2019 | 09:55 PM
  #202
_zebra's Avatar
makes children cry
hmm... well i ain't sure it's worth the extra $120 buying local vs rockauto to maybe see if i could reuse my stuff & return the 6.0 gear... but then again, it'd save $450 to reuse my current clutch/flywheel (that is, until i burn through it & end up having to tear into it again later - putting the 6.0 stuff in anyway)
Old 11-21-2019 | 05:33 PM
  #203
Pulled some more parts off the 4.8 including the clutch. Anyone an expert on clutch wear? Trying to figure out if I should reuse this one, however to my unskilled eye it looks pretty rough.
Old 11-21-2019 | 07:12 PM
  #204
Also tore down the 4.8 just for kicks. Less carbon buildup than I expected and nothing shows sign of imminent failure. Anyone want the heads?
Old 11-21-2019 | 07:38 PM
  #205
arthursc2's Avatar
I'd run that clutch, but being where you are just replace it. I don't like doing **** twice. It's like being in there to do a clutch and not doing the rear main as well
Old 11-21-2019 | 07:44 PM
  #206
Yeah I know it will hold long enough for me to start enjoying the new power but like you said I also hate doing stuff twice. I think I'll just put this one in the spare parts bin and look for an upgrade.
I emailed Midwest transmission asking for their recommendation since they sold me the trans. It's hard to find clutch info that's not about a 5.9 cummins. I really don't want a hardcore clutch that's a pain to drive.
Old 11-21-2019 | 08:17 PM
  #207
_zebra's Avatar
makes children cry
Southbend dual disk!
dude, i'm just going with a LuK
...but i'm also just working with a cammed LM7
LT1-S in the vette... which is fun from a stop in a 3200lb car.
Old 11-21-2019 | 08:43 PM
  #208
1FastBrick's Avatar
Custm2500's Rude Friend
How's the top side of those heads look?
Old 11-21-2019 | 09:10 PM
  #209
_zebra's Avatar
makes children cry
see below
Originally Posted by dantheman1540
Old 11-21-2019 | 09:23 PM
  #210
1FastBrick's Avatar
see below
That's the frame or something else. I scrolled up and they actually look fairly good.
Quick Reply: Dirty Dan's RCSB 4X4
