Dirty Dan's RCSB 4X4
#201
No No No! The 4.8 clutch was nearly non existant and the flywheel had some serious hot spots. The NV4500 clutch I got was just to OEM specs I think it's a LUK. I've already put right at 30k on the nv4500 swap. I never even really broke the clutch in. I remember leaving Smith's off road and matting the throttle in first gear spinning the tires in their lot. It was open header when I left their shop because they didn't have an exhaust bender.
But since they are the same 12in size unless the pressure plate is much different which it likely is. The clutches could be interchangeable.
Unless I'm missing something else very obvious.
#202
hmm... well i ain't sure it's worth the extra $120 buying local vs rockauto to maybe see if i could reuse my stuff & return the 6.0 gear... but then again, it'd save $450 to reuse my current clutch/flywheel (that is, until i burn through it & end up having to tear into it again later - putting the 6.0 stuff in anyway)
#203
Pulled some more parts off the 4.8 including the clutch. Anyone an expert on clutch wear? Trying to figure out if I should reuse this one, however to my unskilled eye it looks pretty rough.
#206
I emailed Midwest transmission asking for their recommendation since they sold me the trans. It's hard to find clutch info that's not about a 5.9 cummins. I really don't want a hardcore clutch that's a pain to drive.
