Droppin More Quarters Then Michael J Fox @ a Parking Meter (pic heavy)
Old 12-13-2013, 11:29 PM
  #21
AUTOT3K's Avatar
the only packages that I cared about showed up today!
Brian tooley link lifters
PRC Stage 1 243 heads shaved 0.035" /w double springs
ASP underdrive pulley's
Gaskets
ARP Head Studs + Crank Bolt
& Comp Cam Push rod length checker
Old 12-13-2013, 11:32 PM
  #22
AUTOT3K's Avatar
I don't have the instructions in front of me, but for the ARP studs, the larger ones it said I believe 3 steps to final torque of 80 ft/lbs....easy enough
but the small ones was like final torque of 25 ft/lbs....so do I do 3 steps with those?
torque the large ones to say 20 ft/lbs first pass and the smaller ones to like 5 ft/lbs?
Old 12-13-2013, 11:34 PM
  #23
AUTOT3K's Avatar
and my comp pushrod checker didn't come with instructions at all, but I saw online that each HALF turn is .050" is that correct? so each full turn would be 0.100"?
how do I measure the half turns more accurately? they have a nice marked line on the one side to line up for full turns but nothing marked on the back!
and since my current rods are at 7.425" and I'm slapping on 0.035" shaved heads, should I start my checker at 7.350" and go from there?
Old 12-14-2013, 01:03 AM
  #24
sprayed99's Avatar
Get a 12" caliper to measure the OAL of the pushrod tool.
make sure you are not compressing the lifter plunger. turn the pushrod tool to zero lash. Pull it and measure the push rod tool. Then add the recommended lifter preload. I would contact BTR and ask him what would work well with his lifters.
Old 12-14-2013, 01:07 AM
  #25
sprayed99's Avatar
install all the studs.
Do the first torque value for the large studs. Then "snug" the small studs . then go to the 2nd and 3rd values for the large studs. Last torque the small studs down to the value specified by ARP
Then drink and beer because you are done
Old 12-14-2013, 10:14 AM
  #26
AUTOT3K's Avatar
coffee time then undo head bolts and pull not bad for2 hours
Old 12-14-2013, 12:04 PM
  #27
oakley6575's Avatar
You need to go by the marks on the pushrod length checker.. Do not measure the OL of the checker because that is not how it is designed to work and will be inaccurate. When the checker is at its shortest, it is 6.800", and each full turn is .050". Check out post #2
comp cam pushrod length checker, how to use? - Corvette Forum
Old 12-14-2013, 12:41 PM
  #28
AUTOT3K's Avatar
Ive hit a snag
for the coolant cross over tube or steam vent I think its called. My factory heads the rear one is blocked off. The prc heads that hole is open. What can I use to plug it?
Old 12-14-2013, 01:09 PM
  #29
10 Second Truck Club
RS/SS 4.8's Avatar
Just transfer the ones from your factory heads to the new heads. It should have a 10mm bolt holding down a "plug" on the rear of each head.
Old 12-14-2013, 01:18 PM
  #30
AUTOT3K's Avatar
No my old heads the coolant hole is like welded over or riveted so theres no plug to transfer over
Quick Reply: Droppin More Quarters Then Michael J Fox @ a Parking Meter (pic heavy)
