Earliest Magnuson blown "Trailblazer"
Wow Phil, when you told me you had some custom headers, you really meant it. That split collector is a really ingenious design. I'm impressed. Is that your steering shaft going right through the drivers side header? Impressive use of space. I want some info on the accessories you used. They look great.
Let me know when you get it all finished and tuned. I really want to take a spin in that thing.
Picture Updates
A few recent pictures:
Next week is the cooling system, remote oil filter and cooler, front engine accessories. Following week, wiring harness and startup. Then shift kit, 3.73 gears for the rear (to match the front 3.73's) and engine breakin. Then to the dyno.
I can taste it...........................
Top of motor:
90mm C6 Throttle body - A/N fittings for intercooler:
Hard lines replaced rubber vacuum lines:
FP Regulator on CNC milled bracket:
Thermal coated Stainless headers, Wilwood Polished Master Cylinder not yet installed on Hydroboost.
Upper exhaust system routing:
Rear merge collector - behind cats leading to Magnaflow 3.5" muffler
Muffler - 3.5" in/out
Going to cover the coils with a black painted smoothed LS2 type cover with C6 Corvette flags on each.
I've decided on the same flags for the sides of the truck also:
Top of motor:
Man, your goin to confuse the crap out of some people with that thing!!!
It looks great! Looks like alot of Patience has gone into this truck!!
Keep up the good work!!!!!
