Earliest Magnuson blown "Trailblazer"
Old 09-10-2007, 09:38 PM
  #21
KySilverado's Avatar
Damn, **** load of nice work going on with that project. I envy you guys that can fab things. Great work!
Old 09-10-2007, 09:42 PM
  #22
what a rush!
moregrip's Avatar
your project looks really well put together, nice attention to detail
Old 09-10-2007, 09:46 PM
  #23
philntx's Avatar
Thanks, also trying to hide all of the underhood wiring harness I can.
Building air intake ducting out of 4" aluminum tubing, TIG welded to make it look like one piece.
The A/C compressor is going to be up and on the passenger side, using a slightly modified Newman A/C bracket/tensioner and a polished Sanden compressor.
More pics next week.
Old 09-10-2007, 09:49 PM
  #24
what a rush!
moregrip's Avatar
very nice, I'm close to having to tackle intake tubing as well, been going back and fourth between aluminum, stainless steel, and rubber/silicone
Old 09-10-2007, 09:53 PM
  #25
philntx's Avatar
I may Jet hot coat the intake tubing the same as the headers. I used a "crystal Black" coating.
I have a source for mandrel bent 4" pipe if you need it.
Old 09-10-2007, 10:00 PM
  #26
what a rush!
moregrip's Avatar
thanks bro, if I end up needing some I will give you a shout
Old 10-11-2007, 10:20 AM
  #27
philntx's Avatar
Default Few Pics of the oil coolers
Getting closer:
Transmission and engine oil coolers:
Installed: Side shot from passenger side frame rail. Front is to the right.
Front View: This view is the top of the cooling assembly. Fans are thermostatically controlled.
Parts: These are all of the components broken down.
Bracket: This is what the fans/shroud and cover bolt to. Heavy duty side flanges bolt to frame.
Shroud:
Old 10-11-2007, 11:09 AM
  #28
TOTM: January 2007
Last Call's Avatar
Looks great man!!
That little heat exchanger might have trouble keeping that Maggie from getting too hot.
Old 10-11-2007, 01:10 PM
  #29
philntx's Avatar
These are just the trans fluid and the engine oil coolers. The radix heat exchanger is in front of the radiator.
Old 10-21-2007, 11:27 PM
  #30
what a rush!
moregrip's Avatar
you do some damn fine work
Quick Reply: Earliest Magnuson blown "Trailblazer"
