Earliest Magnuson blown "Trailblazer"
#33
Thanks guys.
Had to CNC a new bracket for the A/C to tuck it in closer to the passenger side head. Trial fit the S&P A/C bracket, but it didn't have a tensioner.
This will allow the battery to go in the stock location.
Will have a pic maybe by Friday.
#36
Sorry, but I've been traveling with on work projects:
Update: Starting it this week:
Tow/haul circuit installed, harness installed, interior re-installed, NP246 installed in place of the stock NP236 transfer case.
New A/C bracket built and installed.
New gauge pac:
Spare tire compartment built: Also has JL stealth sub, amps, Caps, crossovers, and XM circuits
Went with a Mercedes ML350 spare tire (same diameter as the tires on the truck. Re-drilled bolt pattern on wheel.
Exhaust:
Spintech muffler where spare tire used to go:
3.5" in/out Magnaflow muffler in normal location.
Dual Cats:
To be done:
Intercooler heat exchanger installed, Air induction system built from 3.5 aluminum tubing, filter box built, 3.73 gears and posi installed in rear, 4L65E Shift kit, chrome A/C bracket, odds and ends, steam clean and detail undercarriage, etc, etc, ad infinitum (right moregrip!)
New gauge pac:
Exhaust:
Dual Cats:
To be done:
