El Bandito
#101
So I know of 5 grounds that I have done properly.
1. Starter, I thought one of those wires was a ground? Maybe not though
2.There is one coming from the back of the block to the frame the braided cable pretty sure that is the engine ground?
3.I have one random one on the passenger side coming out the harness I have it grounded to a cylinder head in the back
4.I have the ground that is coming from the harness at the bottom of the harness in front of the block grounded to the same spot
5. Negative battery cable grounded
Not sure what I’d be missing after that but I am with certainty that those 5 are all good.
Also alternator ground forgot about that one
#103
Just took a recording of me starting the truck up to show my problems a bit. I’ll have it up later tonight. I forgot to mention I have no motion in my fuel gauge at all as well
#104
I think I already mentioned my fuel gauge doesn’t work either but oh well
That is the truck starting. Sounds like *** I know I am hoping it will be driveable by Monday but I don’t know
#105
100% Redneck
Hey sounds good to me. re- check the connectors around and under the engine fuse block. I forgot a blue plug under the block and my fuel gauge didn't work.
The headlamp harness has a ground that screws into the radiator support on the left (drivers) side.
#106
Blue plug under the engine fuse block? hmmm I will look for that
#107
This is all the ground points that I have I may have missed something but pretty sure I covered everything let me know what you think
#108
100% Redneck
I don't have anything connected to that firewall stud either. It has an empty tab just like yours... why I don't know.
On the rear where you said the ground connects to the head... that ground actually is on the block with a vertical bolt down to the block. It shouldn't really matter IMO. but the correct way is on the block as you can see on the diagram below with the #1 wire. Number 8 is for vehicles with a battery mounted behind the coolant reservoir so disregard #8. The second pic shows a smaller ground that's piggybacked off of the main battery ground.
#109
Truck is kill.
Back to not running again. Dropped my battery off to get it charged and tested because it is having bad battery symptoms. Truck ran earlier today but then when I went to start it tonight it did not run at all. I'll pick the battery back up tomorrow and see if it is any good.
I did tighten the ground on the back of the block because it was a bit loose to see if that would do something, nothing.
I also moved the negative battery ground from the head onto the power steering pump bracket and I think that it is better than the head, still nothing.
Currently I am a one man work force with my think tank father having a blown out knee this weekend I have an uncle coming into town and we will try and see if we can figure it out. If this proves no avail I will trailer it south and see what I can do at my uncle's transmission shop. My other uncle has done this swap before and he will be able to help and his mechanics who may have some better input. Don't like doing that but at least I am still there to learn, work and watch rather than send it to a shop and have someone else do it without me being there and having a hand in it.
Also may have figured out the problem with my auto headlights and gauge cluster, I'd tell you but don't want to jinx it. Fingers are crossed
#110
100% Redneck
The negative battery cable has a place on the block piggybacked to a smaller ground. See last pic I posted above... look at the number 5 & 4 wire. Ground is ground but that is the correct battery grounding place on the block.
