El Bandito
#252
And if I had known then what I know now probably would have told him to do it different lol
arthursc2 (05-05-2021)
#254
Also almost picked up some new Denali wheels ALY5699s in the grey/polished look. Anyone have any pics of these on my truck? They are starting to grow on me and I might still buy a set
dantheman1540 (05-05-2021)
#256
I’ll dig up the repair and look and tell you exactly but I had the entire system replaced I think
#258
That’s pretty much my MO every time a code pops now that is some sort of emissions crap. No need to dump money into emissions when this truck is going to be turboed and not compliant anyways
#259
Here is a WOT log. I did a 2nd gear pull and just spun out and it shifted and said nope so did not attempt that again.
Also bank one knock sensor came back, definitely false knock and I am just about to turn the damn light off cause I don't think it is the sensor but it might be.
#260
100% Redneck
Raising the numbers in the knock sensor level tables will desensitize the sensors.
I'd start with maybe raising them 10% and see if that stops the code. HP Tuners doesn't have a percentage box you can click but the math is really simple. To raise the table 10% you type 1.10 in the box and hit multiply. If you want 20% type in 1.20 and multiply etc. To lower 10% you'd type in .90 then multiply.
Raise both the "Tip in" and the "RPM vs Cyl" (shown in red)
1. click the empty box to highlight the table
2. type in your number value
3. click multiply
4. "save file as" (raise knock values 5-7-21 or whatever)
5. flash
dantheman1540 (05-07-2021)
