El Bandito
Old 09-24-2020, 08:34 PM
  #21
dantheman1540's Avatar
Heck no can't beat beat free with a stick! The 862s on my LQ4 feel strong maybe one day I'll get a power number but for a budget head I don't feel them fall off or choke power.
Old 09-24-2020, 09:13 PM
  #22
shakenfake's Avatar
Received 1,271 Likes on 970 Posts
Glad you like them and can share some real world exp. I am taking them to the machine shop tomorrow to get them checked out
Old 09-25-2020, 09:24 AM
  #23
shakenfake's Avatar
Quick question, should I swap my ecm? I have the matching 6.0 ecm that I can swap as well or should I keep my 5.3 and just retune it?
Also drive by cable/drive by wire, what do I need to do to get around that? I honestly thought I had a link somewhere that answered my question but I cannot remember.
Old 09-25-2020, 10:10 AM
  #24
if you want a little bump in flow have them cut 2" valves into them.
Old 09-26-2020, 03:13 PM
  #25
shakenfake's Avatar
Engine made it out the bed of the truck a few days ago!
Also dropped my heads off at the machine shop so they could get a bath and checked out as well as to install my LS6 springs.
dantheman1540 (09-27-2020)
Old 09-29-2020, 01:30 AM
  #26
shakenfake's Avatar
Alright just want to set my shopping list out there and make sure I am not missing anything, if anyone could give me some feedback that would be great,
ACDelco Spark Plugs 6 x8-----RockAuto
NGK 51033 Spark Plug Wires-----RockAuto
Fel-Pro Head Gasket Set HS26192PT2-----RockAuto
Timing Chain Adapter Bracket TFS-30675600----Summit
Tune---Mailordertuner.com
ARP Head Bolt Kit 134-3610------Summit
ARP Header Bolt Kit 134-1202----Summit
LS7 Lifters------MichiganMotorsports do I need new trays as well?
Texas Speed 212/218 Cam #25-TSPLL212218-----Probably from my tuner maybe from TX Speed
Tensioner Pulley ACDelco 38009------RockAuto
ACDelco 6K930 Serpentine Belt-----RockAuto
LS2 Timing Chain 09-0029------Summit PN
Anything I am missing here? I have oil of course but I am not sure if I am missing something else.
Old 09-29-2020, 11:36 AM
  #27
Jeff71's Avatar
On the TSP cam, call around to find one in stock, if possible. I ordered mine from TSP and they cut to order, I believe, and it took 3 - 4 weeks to get it from them.
Old 09-29-2020, 11:47 AM
  #28
tjmath's Avatar
Any reason you're going with AC delco plugs over NGK's?
Great choice on the tuner.. Casey tuned my 99 and he is an awesome dude.
Old 09-29-2020, 11:49 AM
  #29
100% Redneck
RedXray's Avatar
Received 1,334 Likes on 794 Posts
Add a cam retainer plate to the list. I use the MAHLE B31822 from Amazon ($18). You will need new lifter trays. The last thing you want is a lifter turning inside a worn or cheap chinese lifter tray. Buy the GM Performance LS2 trays part number 12595365.
Old 09-29-2020, 12:11 PM
  #30
shakenfake's Avatar
I couldn't find NGK part numbers, kept getting confused and basically running around in circle's looking for them so I just choose ACDelco.
Casey tuned my Uncle's supercharged 01 and I was there for a dyno, he is an amazing dude.
Lifter trays came with those lifters iirc but I will go back and check. Retainer plate added now.
Yeah my tuner has them in stock so I will order from him.
Quick Reply: El Bandito
