El Bandito
#31
100% Redneck
Do those 862 heads have the notch on the sealing surface? Some have had coolant leaking issues using a standard MLS type head gasket with notched heads. The WS6 store has a special sized head gasket for 4" bore blocks using the 862 notched heads (RPMSPEEDHG02). If you have the notch do some research... if not disregard.
#32
Anyone know anything about LSXceleration website? They seem to be the only ones that I can find the lifters from, I see them on amazon but they are $180. On LSXceleration they are $160 with trays.
#33
#34
100% Redneck
If they have the notch buy only the gaskets you need separately. The exhaust gaskets that come in that felpro kit are the bi-metal type and will leak. Use GM oem gaskets or the MAHLE MS16124 they are exactly like the GM gaskets and much cheaper ($15) pair at Amazon.
#35
100% Redneck
Those are the Delphi bulk lifters. I had one set of those used with two different camshafts. I couldn't get rid of the sewing machine noise using two different pushrod lengths. It may just have been a bad set but I measured with a pushrod checker and never could quieten them down. The real Delco LS7 lifters (12499225) are $260 plus and I'm guessing all the cheap LS7 "type" lifters you see everywhere are the Delphi bulk lifters. I went with the Morel 6504 lifters ($209 WS6 Store no tax free shipping) and they've been super quiet up to my 7000 rev limit.
#36
#37
Also I meant to ask you this question before, what flywheel did you use to mate your LQ9 to the 4L60? I was going to use the one off my 5.3 as I thought that the one from the LQ4 was too large or had something up with it that didn't allow it to fit right.....
#38
Oh and also why change the cam retainer plate? Just curious as I think I have seen it before but not on every cam swap.
#39
Cam retainer has an o-ring in it and at $18.00 it's cheap insurance.
RedXray (09-29-2020)
#40
100% Redneck
The mic on my GoPro cuts in and out but you can hear the lifter noise. It was annoying inside the cab below 35mph
Yeah your LQ4 had a 4L80 from the factory. All LQ9's came factory with a 4L60 transmission so I just used the one that came with my engine. So yeah the 5.3 flexplate that mates to the 4L60 will work.
