El Bandito
Old 09-15-2021, 08:34 PM
  #391
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
So what do yall think? Oil Pressure sending unit or cam position sensor? I am inclined to replace both but just wondering what you guys think if it may be the oil pressure sending unit.
Old 09-16-2021, 07:04 AM
  #392
wretched73's Avatar
From what I can see, neither look like the culprit
Old 09-16-2021, 07:07 AM
  #393
shakenfake's Avatar
I wiped my finger on that scungey cam sensor and it was just wet. To me that looks like dirty oil. Keep in mind I have not started the truck since Sunday so it isn’t going to be fresh.
Old 09-16-2021, 09:49 PM
  #394
shakenfake's Avatar
So it looks to be the oil pan gasket. I will post some pictures later but I have a hard time believing it is rear main for two reasons.
1. I don't really see any oil inside the bellhousing. If it was a rear main there would be a ton but there is nothing in there it seems.
2. It is leaking on one side of the engine in the corner where you are supposed to put RTV, I guess I may not have put enough.
Edit: Can anyone tell me what oil filter I need? The one I usually buy is sold out. I like the long ACDelco one but I only have the Wix and it won't cross reference
Double Edit: PF61, found it I'm an idiot
Old 09-17-2021, 06:37 AM
  #395
dantheman1540's Avatar
It's possible the oil pan bolts got loose and just need snugging up.
Old 09-17-2021, 06:45 AM
  #396
arthursc2's Avatar
Received 1,498 Likes on 1,098 Posts
Whats wrong with Wix?
Old 09-17-2021, 06:48 AM
  #397
It rhymes with Dix
The following 3 users liked this post by dantheman1540:
shakenfake (09-17-2021), tjmath (09-17-2021), zz454Chevelle67 (09-17-2021)
Old 09-17-2021, 07:06 AM
  #398
shakenfake's Avatar
That was the first thing I checked, the bolts are snug as a bug.
Nothing is wrong with Wix but they were sold out for me so just got AC Delco
Old 09-17-2021, 10:46 AM
  #399
shakenfake's Avatar
Some pics. I believe it is leaking in that top corner where you put the rtv and falling down the back. I took the starter cover off and there is nothing on the flex plate or anywhere I can see
arthursc2 (09-17-2021)
Old 09-17-2021, 11:03 AM
  #400
That dye is pretty sweet! Look's like you need to reseal that or, remove the 5w-30 and add 6qts of Lucas stop-leak molasses and a bag full of saw dust.
The following 4 users liked this post by dantheman1540:
Jeff71 (09-17-2021), shakenfake (09-22-2021), tjmath (09-17-2021), wretched73 (09-17-2021)
Quick Reply: El Bandito
