El Bandito
#421
My 99 had buckets and when I bought the 14 I searched for split bench for that exact reason @dantheman1540.
dantheman1540 (10-07-2021)
#422
Replaced my oil pan gasket last night. Needed to drop the steering to pull the pan cause it kept hitting the baffle that is below the crank? Idk what it is called.
What metal in the oil pan?
wretched73 (10-09-2021)
#424
I put a magnet in there and nothing stuck to it so I don't think so. I washed it all out before I put my pan back on
#426
With what like an axe?
I do have a saw I guess lmao
#428
Thank you couldn't remember what it was called might be retarded though.
I was thinking it might be casting flash but can that show up again? I've already pulled the pan once I figured I would have got all of it out the first time
edit: by loose do you mean I can't move them in the pan? Cause there are pieces of slag basically in the pan that creates a rough surface but that stuff I could wipe out
#430
Yeah I have some of that. This stuff I could move around and stuff. I used brake cleaner and sprayed it all out.
