El Bandito
Old 10-07-2021, 11:30 AM
  #421
tjmath's Avatar
My 99 had buckets and when I bought the 14 I searched for split bench for that exact reason @dantheman1540.
dantheman1540 (10-07-2021)
Old 10-09-2021, 01:37 PM
  #422
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
Replaced my oil pan gasket last night. Needed to drop the steering to pull the pan cause it kept hitting the baffle that is below the crank? Idk what it is called.
What metal in the oil pan?
wretched73 (10-09-2021)
Old 10-09-2021, 05:37 PM
  #423
wretched73's Avatar
is that metal magnetic?
Old 10-09-2021, 08:40 PM
  #424
shakenfake's Avatar
I put a magnet in there and nothing stuck to it so I don't think so. I washed it all out before I put my pan back on
Old 10-10-2021, 09:22 AM
  #425
dantheman1540's Avatar
Cut the filter open
Old 10-10-2021, 01:18 PM
  #426
shakenfake's Avatar
With what like an axe?
I do have a saw I guess lmao
Old 10-10-2021, 01:43 PM
  #427
Custm2500's Rude Friend
1FastBrick's Avatar
The windage tray is the baffle you are refereeing to.
The oil pan castings are really rough and have casting flash in them. If its not magnetic and its not loose its the casting flash.
Old 10-10-2021, 01:49 PM
  #428
shakenfake's Avatar
Thank you couldn't remember what it was called might be retarded though.
I was thinking it might be casting flash but can that show up again? I've already pulled the pan once I figured I would have got all of it out the first time
edit: by loose do you mean I can't move them in the pan? Cause there are pieces of slag basically in the pan that creates a rough surface but that stuff I could wipe out
Old 10-10-2021, 01:52 PM
  #429
1FastBrick's Avatar
Casting flash is from the manufacturing process, most of it is bonded to the pan. Usually, you have sand it off to get rid of it. Some times you can knock it off if it has a weak bond.
the casting flash Is like splatter when they poor the aluminum.
Old 10-10-2021, 01:56 PM
  #430
shakenfake's Avatar
Yeah I have some of that. This stuff I could move around and stuff. I used brake cleaner and sprayed it all out.
Quick Reply: El Bandito
