El Bandito
Old 10-11-2021, 07:43 AM
  #441
shakenfake's Avatar
Received 1,276 Likes on 973 Posts
I'm thinking crank. I guess I need to pull the starter. The oil level sensor doesn't seem to be leaking. I don't think the oil would travel to the same corner of the pan.
Last time I took out the starter I almost shocked the **** outta myself lmfao
Also I noticed that my header touches my frame which explains why my y-pipe was so retarded to install. Guessing that means my motor mounts are shot. I'll probably pick some up in late December or November.
Old 10-11-2021, 09:51 AM
  #442
wretched73's Avatar
1. I have a set of solid atomic fab mounts for sale
2. UNHOOK THE BATTERY FIRST, C'mon man! Ya gotta do, ya know, the thing
Old 10-11-2021, 09:53 AM
  #443
shakenfake's Avatar
I thought I did that time! I was also in a rush at like 3 in the morning so probably that
Yeah definitely will get with you if you still have them in a month. I just bought a DJM LCA and next week is the rest of the drop kit My wallet is hurting so bad right now
Old 10-15-2021, 08:42 AM
  #444
shakenfake's Avatar
LCA delayed from yesterday. Apparently arriving today. Probably will have the coilovers put together tomorrow morning or afternoon. Sunday I may install everything up front and see where I want it to sit. That will determine what drop kit I buy for the rear.
Old 10-15-2021, 08:45 AM
  #445
dantheman1540's Avatar
Prepare to jack the truck up and let it down at least a dozen times to get the coilovers even side to side. Also don't skimp on the anti sieze when assembling them, it makes a huge difference in being able to easily adjust them.
Old 10-15-2021, 08:51 AM
  #446
shakenfake's Avatar
I used a ton when I was doing a mock up assembly. I was too lazy to walk down the street to get on the vice.
I won't lie I am a bit nervous with all I got lol I'm putting full faith in Atomic's genius here. 2" lift coilovers and a 4" drop LCA to get a 2" drop with the possibility to adjust it down to a three inch.
The shock is short as **** though, the rear ones are longer than the front which is weird but I believe it is because the mounting points are farther so I think that makes sense.
My peanut brain can't handle these sorts of measurements.
Old 10-15-2021, 08:58 AM
  #447
The only way to find out if it's right is to slam that **** together!
Old 10-15-2021, 09:02 AM
  #448
shakenfake's Avatar
Dumbass work computer keeps downloading pictures as .jfif holy **** it is annoying
Send it!
Old 10-15-2021, 09:11 AM
  #449
Call the IT guy
Old 10-15-2021, 09:13 AM
  #450
shakenfake's Avatar
I don't care enough to make myself do more work. If nobody else in the building complains it doesn't exist in my book
Quick Reply: El Bandito
