El Bandito
#552
Something like that
#553
100% Redneck
It's not the discoloration of the arms. I broke off one of the spray nozzles somehow and now part of my windshield isn't getting sprayed by wiper fluid and the nozzle is hanging from the arm all retarded-like. I also think they are kind of bent and don't wipe the windshield completely.
Must be one of those Silverado LTZGB non binary trucks that's had it's VIN altered
The following 3 users liked this post by RedXray:
#554
The Dorman arms are $22 at O’Reilly last I looked
I will try the steel wool as well. Why not delete the wiper arms then?
Also I have noticed you have been a bit less active recently
#555
Kinda want to return my c-notch and get my money back since I never installed it....
Any opinions? Should I just install it later? I have the Belltech bumpstops on since my McGaughys were sitting on the axle. That may answer the question though
#557
Gonna have to go and measure it tonight. I'm guessing 2-3 inches.
#559
100% Redneck
Yes make sure you have an abundance of travel. Hitting the bumpstop at speed will separate the tire from the pavement.. then it's white knuckle driving at best.
The hardest part installing the c-notch is all the drilling, first the pilot then the IIRC 1/2" holes???
I cut both sides of the frame with one sawzall blade... bought a pack of blades thinking It would be a tough cut... cut like butter. Drill two top holes in your pattern, this will keep the frame from cracking when the cut transitions from vertical to horizontal.
#560
A sawzall didn't think about that. Was going to do a cutting wheel.
You mean two holes where my red marks are correct?
