El Bandito
#582
Mine aren't the heated back kind only the ***
tjmath (01-20-2022)
#584
Finally corrected my gauge cluster's mileage. This is maybe 50 miles off at most. The tool I used you need to input in KM which then goes to Miles which then goes to binary that the EEProm reads. It will never be perfect but it is perfect to me
No before pic but it was at like 278k or something. I got the cluster at 268k and swapped when I did my engine swap. I have dropped it down to what it should be. I would have had a before pic but I got too excited and forgot
#587
Another small update but I got my side mirror switch actually working again. Swapped it out with a new one and soldered in a blue light and presto all good!
I am in the process of using some epoxy to get my light switch wires to stick to the board. That thing has been a PITA since solder won't stick. We will see what happens but it should work I think. If not I am not really worried about it, I have a backup plan, the epoxy is a fun experiment though
Update: Epoxy worked. Finally done with this switch after like 3 design iterations.
#588
New wiper arms installed and working good.
#590
Still broke!
Supposed to get towed down to Austin this weekend. I did say that last weekend and the weekend before that though...
But this time I'm serious
Just knocking out some little things when I have had time.
wretched73 (02-09-2022)
